Doepfer
New poll for Doepfer_a100
2006-11-24 by Doepfer_a100@yahoogroups.com
Enter your vote today!  A new poll has been created for the
Doepfer_a100 group:
How would you like the forthcoming A138d crossfader module to be realized? [for a suggested module sketch look here:
http://www.doepfer.de/a138d.htm ] regarding your options to choose from: 1. A complete module similar to the suggested A-138d
2. An expansion module that has to be connected to an existing A-138 (a or
b). This would be a little bit cheaper as the electronics of the A-138 can
be used (but not much as the electromechanical parts remain the same and the
electronics is not very expensive). For this solution the single outputs
would not be available and a little bit of soldering is necessary (2 wires
have to be soldered to the A-138). I don't think that this solution is
meaningful.
3. same as 2. but only as a DIY project. It's very simple. Most of the work
will be the front panel processing. The "electronics" is only a few
resistors some potentiometers. I can publish the schematics on the A-100 DIY
page.
  o option 1.
  o option 2.
  o option 3.
To vote, please visit the following web page:
http://groups.yahoo.com/group/Doepfer_a100/surveys?id=12471627
Note: Please do not reply to this message. Poll votes are
not collected via email. To vote, you must go to the Yahoo! Groups
web site listed above.
Thanks!
Re: New poll for Doepfer_a100
2006-11-24 by appliancide
I think this would be a great module if it were a bit more flexible
and performance-oriented.
CV in for the crossfader would be nice. CV ins for all of the ins and
outs would be awesome.
Transform buttons, like the ones on DJ mixers, would be a nice touch
for live use/mixing. A gate option here would add a lot of flexibility
to the module.
I would also be willing to sacrifice a little extra cash as well as
some panel space for a better/bigger crossfader. A modulation wheel or
removable crossfader (again borrowing from a DJ mixer) would be cool.
Would this also work as a cv mixer or is that not possible?
Anyways, long story short, I would like to see this module do as much
as possible.
Cheers
> Doepfer_a100 group:
(a or
A-138 can
and the
wires
> meaningful.
the work
A-100 DIY
> page.
>   o option 1.
>   o option 2.
>   o option 3.
> Thanks!
AW: [Doepfer_a100] Re: New poll for Doepfer_a100
2006-11-27 by hardware@doepfer.de
The A-134 is a voltage controlled crossfader and can be controlled e.g. from
an external crossfader or modulation wheel that simply generates the control
voltage for the A134.
Best wishes
Dieter Doepfer
  -----Ursprüngliche Nachricht-----
  Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]Im
Auftrag von appliancide
  Gesendet: Samstag, 25. November 2006 01:11
  An: Doepfer_a100@yahoogroups.com
  Betreff: [Doepfer_a100] Re: New poll for Doepfer_a100
  to the module.
  as possible.
  Cheers
  > Doepfer_a100 group:
  (a or
  A-138 can
  and the
  wires
  > meaningful.
  the work
  A-100 DIY
  > page.
  > o option 1.
  > o option 2.
  > o option 3.
  > Thanks!
Re: [Doepfer_a100] Re: New poll for Doepfer_a100
2006-11-27 by Florian Anwander
Hi Paul
This module _is_ performance orientated. This means: real manual work,
no cv. It is a simple crossfader for real live stage action.
If you want cv control a dedicated crossmixer is obsolete, because it
can be achived by VCAs and/or VC-mixers and an voltage inverter.
Ok, it has a mute toggle switch. Something like the inversion of a
Transformer button.
> to the module.
Again: simple VCAs can do this already.
> as possible.
I'd like to have simple modules. If I want complex functions, I combine
several modules.
Florian
Re: AW: [Doepfer_a100] Re: New poll for Doepfer_a100
2006-11-30 by James Husted
A panel with two standard mod wheels would be very nice to compliment
this and other modules. One wheel could be the standard mod function
with a low-to-high output voltage and the other would be the standard
pitch bend configuration with bipolar CV out. A removable spring
return or just a heavy center detent would be great. Just mounted in
a panel with the output jacks at the top and your ready to go (range
adjustment could be at the receiving module). As a added cool factor
- if the wheels were clear plexiglass - sidelight them with a blue
led. VERY cool looking. Even better would be a blue/red or other
combo that would change through the color spectrum as the wheel was
moved. I know that is pretty wild but a bank of them in the bottom
row of a portable case would look very, very, cool.  Why should only
the light show guys have the fancy looking rigs!
> e.g. from
> the control
> Best wishes
> Dieter Doepfer
James Husted
The ErsatZ Planet Graphics and Sound
http://homepage.mac.com/ersatzplanet/
james.husted@mac.com
"Welcome to the first day of the rest of your money..."
2006-11-30 by Florian Anwander
Hi James
> moved.
I would knee down, if someone would build such a modwheel ;-)
Nevertheless: a Modwheel module would be a really great addon. As the
crossfader.
Florian
AW: AW: [Doepfer_a100] Re: New poll for Doepfer_a100
2006-11-30 by hardware@doepfer.de
A collection of controllers (wheels, joystick, buttons) is planned for the
control box (expansion box for the planned CV/gate keyboard). I believe that
a horizontal mounting of the controllers is more useful that a vertical
mounting in a module. But if there are sufficient inquiries we could offer a
"wheel module". How about a poll ?
Best wishes
Dieter Doepfer
Re: AW: AW: [Doepfer_a100] Re: New poll for Doepfer_a100
Hi Dieter
An additional controlbox should be a simple 3HU rack in a desktop housing.
Something similar like
http://www.buerklin.com/gruppen/KapH/H160100.asp
http://www.buerklin.com/images/bild.asp?Bild=KapH/H160100.jpg
So each kind of module could be inserted into this expansion box
Florian
AW: AW: AW: [Doepfer_a100] Re: New poll for Doepfer_a100
> Hi Dieter
> planned for the
> believe that
> could offer a
> Florian
How about the new "A-100 beauty case" :-)
Details on the news page of our website.
Dieter
2006-11-30 by travesty14850
8-0
OMG, I can't believe you're doing this...that is hilarious!  It'd be a
cinch to work up a little one-osc mini-synth...fantastic!
> Dieter
Re: AW: AW: AW: [Doepfer_a100] Re: New poll for Doepfer_a100
Hi
The "beauty case" is really great.
But I think the addon case for controller moduls should fit smoothly to
the keyboard. Imagine something looking like the monomachine
http://www.monomachine.com/img/showroom/sfx6_05.jpg
Florian
Just a little explanation:
We have many customers asking for a small audio processing set with a few
modules only (mainly filters with corresponding modulation sources). So far
we had available only the A-100 miniature power supply but no case. This is
why we decided to offer the miniature case.
I did not mention the plans for the mini case in the group as most of the
members use the A-100 in a completely different way . They tend more to
monster than mini cases ...
Best wishes
Dieter Doepfer
Mini Case?
2006-12-10 by sfrules
People?
"A collection of controllers (wheels, joystick, buttons) is planned
for the
believe that
a horizontal mounting of the controllers is more useful than a vertical
housing.
Florian"
"But I think the addon case for controller moduls should fit smoothly to
http://www.monomachine.com/img/showroom/sfx6_05.jpg"
"How about the new "A-100 beauty case" :-)
Dieter"
Would cases & power supplies of any or all of these be
compatible with Wiard Model 1211 "Joystick Axis Generator?"
sfrules
Re: Mini Case?
2006-12-12 by ilanode
Hello sfrules, no idea wether the JAG will run on +/-12V. Grant will
know. Frac Rack and Euro Rack differ in both FP-size and the position
of the mounting holes. Thus the JAG won't fit into the "Beauty Case"
either of them has to be modified.
If I'm not mistaken the Buerklin case requires an individually
designed FP to which any modules "guts" have to be mounted. Regards, Ingo
--- In Doepfer_a100@yahoogroups.com, sfrules <sfrules@...> wrote:
> People?
> for the
> believe that
> housing.
> Florian"
> Dieter"
> sfrules
A-101 acting strange
2006-12-12 by neil jendon
I just got a 101-1 Steiner filter, and it doesn't seem
to be acting right. The lowpass and bandpass inputs
doesn't pass anything, the highpass passes everything,
the frequency knob does nothing, and the emphasis knob
does nothing but make a thump-thump-thump noise when
it's all the way up.
I've tried all sorts of signals through it to no
avail. Should I send this back to Analogue Haven, or
to Doepfer, or is this something I can fix myself?
-thanks
-neil
Need a quick answer? Get one in minutes from people who know.
Ask your question on www.Answers.yahoo.com
Re: A-101 acting strange
2006-12-12 by djsoysos
Sounds broken to me. Give the nice folks at Analogue Haven a call.
They will take care of it. That filter is very useful, I'm sure you'll
enjoy it when it's working propery.
Soy Sos
AW: [Doepfer_a100] A-101 acting strange
2006-12-13 by hardware@doepfer.de
> Hi,
Do the front panel LEDs react as they should ?
Normally there is nothing you can fix yourself and you should send it back
to Analogue Haven if the module does not work as it should.
Best wishes
Dieter Doepfer
