> Hi,
> I'm designing panels in Doepfer format. Can I confirm that they
> should be 2mm thick?
Yes.
> Second, when making up patch cables, is it necessary to wire the
> sleeves as well as the tips? My thinking is that all the sockets are
> ultimately joined to ground.
As long as connections are made only within the A-100 only the tips would be
necessary as the GND of all A-100 modules is made internally via the
bus/power supply. But if you want to connect a module to a device outside
the A-100 (e.g. filter output to an external mixer, or filter input from an
external audio source) the GND connection is required.
Best wishes
Dieter Doepfer
