Hello,
I did several tests and it seems I really cant get A106-1 to work with either A130 or A124
in the resonance insert simple patch.
BUT IT WORKS FINE WITH A133... A132 I think also works fine...
Is this normal or not?
Best,
Alexandre
> Best,
> Alexandre
It's probably a phase inverting problem. If you insert a voltage inverter
(A-175) that changes the phase by 180 degrees it should work.
Best wishes
Dieter Doepfer
