Doepfer
Broken A-154?
Broken A-154?
2007-02-02 by Jay
Hooked it up properly (checked three times), but it doesn't seem to be
controlling the sequencer. I can step through the sequences using the
manual clock button, but it won't respond to either the internal or an
external clock source. I can clock the sequencer directly using the
"old" way when the master switch is set to on.
Re: [Doepfer_a100] Broken A-154?
2007-02-02 by Bakis Sirros
hello jay,
try pushing the "start" button on the a155 (and the
a154).
best regards,
Bakis.
> doesn't seem to be
> sequences using the
> the internal or an
> directly using the
Bakis Sirros - Parallel Worlds
[Doepfer_a100] group owner
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Don't get soaked.  Take a quick peak at the forecast
with the Yahoo! Search weather shortcut.
http://tools.search.yahoo.com/shortcuts/#loc_weather
Re: Broken A-154?
2007-02-03 by ilanode
--- In Doepfer_a100@yahoogroups.com, Jay <groups@...> wrote:
> Bakis Sirros wrote:
> > hello jay,
> > a154).
> > best regards,
> > Bakis.
> Yep, tried pretty much everything. The first and last pots are set
> correctly too.
Thought that the Note on page 7
(http://www.doepfer.de/a100_man/a154_man.pdf) might be of help. Rgds, Ingo
2007-02-03 by Jay
Bakis Sirros wrote:
> hello jay,
> a154).
> best regards,
> Bakis.
correctly too.
Re: [Doepfer_a100] Re: Broken A-154?
2007-02-03 by Jay
Yeah, I saw that. :-\
2007-02-03 by Florian Anwander
Hi Jay
Maybe some unwanted voltage is connected to the control voltage socket
for firststep or laststep.
Florian
2007-02-03 by Jay
If I press the manual clock button the first or last step controls work.
   My problem is that it won't advance using a clock signal.
AW: [Doepfer_a100] Re: Broken A-154?
2007-02-05 by hardware@doepfer.de
Does the LED of the internal clock oscillator of the A-154 display a clock
signal. Try this settings: clock ~ 7, PW ~ 5, with first stop control = 0,
last step control = 10, mode = 0 (forward). And pay attention to the correct
position of the master switch (right position).
And if you give back the control to the A-155 (master switch = left
position): does the A-155 work like before ?
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] Re: Broken A-154?
2007-02-05 by Jay
Yes, the clock LED is blinking. I've already tried the above settings
combination and it did not work.
Yes.
AW: AW: [Doepfer_a100] Re: Broken A-154?
> display a clock
> control = 0,
> to the correct
> Yes.
The only idea I still have is a poor or broken contact of the clock input
socket. Otherwise you have to send back the module for repair. And be sure
(though I already mentioned that) that the module is not in the CV
controlled mode. In this case the step position is controlled by the CV of
the first step control+CV and the clock input does not work in the usual
way, i.e. not clock triggered step advance.
Best wishes
Dieter Doepfer
Re: AW: AW: [Doepfer_a100] Re: Broken A-154?
2007-02-08 by Jay
I tried to look at if the connectors were soldered in, and everything
looks ok. Oh well, I'll send it back. I just wanted to make sure I
wasn't doing something stupid before I did. ;-)
