> Cheers-
> Has anybody tried making/using ground-lifted patches, just a
> single element tip cable with
> no grounding, like the banana cables in a Serge? Wondering if
> those would work?
> Coleman.
This will work as long as the patch is within the same system as all modules
are grounded via the power supply/bus.
But if you patch between different systems the GND pins of the connectors
have to be connected too.
Best wishes
Dieter Doepfer
