A-135/144 help needed
2007-02-25 by Randall Prentice
I'm a guitarist and I just bought an A-135 and an A-144 to go with my A- 121 and A-146. How do I get these modules to give me a slow, clear morph through all 4 filters? Your help will be appreciated! Randall
2007-02-26 by James Husted
The best way would be to wait for the VC Quadrature LFO A-143-9 and hook it up to the A-135. It will constantly morph between inputs. Try - flanger>echo>phasor>filter. -Jh
On Feb 24, 2007, at 10:00 PM, Randall Prentice wrote: > I'm a guitarist and I just bought an A-135 and an A-144 to go with > my A- > 121 and A-146. How do I get these modules to give me a slow, clear > morph through all 4 filters? > Your help will be appreciated! > > Randall > > > > ------------------------ Yahoo! Groups Sponsor -------------------- > ~--> > Great things are happening at Yahoo! Groups. See the new email > design. > http://us.click.yahoo.com/lOt0.A/hOaOAA/yQLSAA/QnLolB/TM > -------------------------------------------------------------------- > ~-> > > > Yahoo! Groups Links > > >
2007-02-26 by hardware@doepfer.de
> I'm a guitarist and I just bought an A-135 and an A-144 to go with my A- > 121 and A-146. How do I get these modules to give me a slow, clear > morph through all 4 filters? > Your help will be appreciated! The standard patch is described in the A-144 user's manual on page 4. Audio 1...4 of the A-135 have to be connected to the four outputs of the A-121. CV In off the A-144 has to be connected to the A-146 (triangle output). Pay attention that you need an external pre-amplifier to amplify the guitar signal to a suitable level for the A-100 filter (min. 1Vss). The level coming from the guitar directly is much too small for the audio processing modules of the A-100. As already mentioned by jh the A-143-9 (VC quadrature LFO/VCO) is another solution for controlling the A-135 for morphing effects. There is a difference between A-144 and A-143-9 as CV source for the A-135: with the A-144 a CV is used to control the "morph position", the A-143-9 will generate cyclic morphing (1 -> 2 -> 3 -> 4 -> 1 -> 2 ...). Best wishes Dieter Doepfer
2007-02-26 by Randall Prentice
> The standard patch is described in the A-144 user's manual on page 4. Audio > 1...4 of the A-135 have to be connected to the four outputs of the A-121. CV > In off the A-144 has to be connected to the A-146 (triangle output). Pay > attention that you need an external pre-amplifier to amplify the guitar > signal to a suitable level for the A-100 filter (min. 1Vss). The level > coming from the guitar directly is much too small for the audio processing > modules of the A-100. > > As already mentioned by jh the A-143-9 (VC quadrature LFO/VCO) is another > solution for controlling the A-135 for morphing effects. There is a > difference between A-144 and A-143-9 as CV source for the A-135: with the > A-144 a CV is used to control the "morph position", the A-143-9 will > generate cyclic morphing (1 -> 2 -> 3 -> 4 -> 1 -> 2 ...). > > Best wishes > Dieter Doepfer > Ahhh, thanks very much for the help. Can the A-143-9 morph between, say, 1->3? Randall
2007-02-27 by hardware@doepfer.de
> Ahhh, thanks very much for the help. Can the A-143-9 morph between, > say, 1->3? If want to pan between two sources only I'd recommend the panning module A-134 and use e.g. a normal LFO (triangle output) as CV source. If you want to pan between two sources with the A-135 that possible to: for this purpose you have to control two of the VCAs with opposite control voltages. A voltage inverter A-175 can be used to invert the main control voltage (e.g. the triangle output of an LFO) for the second CV input. In this case no A-144 is necessary. But if you have an A-144 available it can be used for this job as well. You have to attenuate the control voltage that is used to control the A-144 (e.g. the triangle output of an LFO) so that only two of the A-144 outputs become active. Best wishes Dieter Doepfer
