Re: [Doepfer_a100] Re: First modular system?
2007-05-07 by Silas Johansen
Hi Pete, On the Doepfer website, under dealers, you'll find http://www.emismusic.co.uk/ in Bristol. /Silas On 5/7/07, Peter Marshall <peter.marshall3@btinternet.com> wrote: > > Hi Max, > > I'm from the UK, living in London but don't know if any stores that deal > with modular synths over here. I've tried a quick search on the net but to > no avail, perhaps my search skills are not up to the job or there simply > aren't any (which I find a little hard to believe). > > As for reading through the docs, that's certainly what I will be doing. I > think I will take my time and examine things carefully as you suggest. > It's > difficult though as I'm really keen to jump in! ;) > > May I ask which modules you chose for your first system? > > Regards, > > Pete > > p.s. your English is very good! > > _____ > > From: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>[mailto: > Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>] On > Behalf Of Maxime > Sent: 07 May 2007 14:29 > To: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com> > Subject: [Doepfer_a100] Re: First modular system? > > Hi Pete, > I bought my first modular system about 6 months ago; It's a 'custom' > (not basic) system only made of Doepfer modules. I chose the modules > by reading the doc on Doepfer website for each, maybe that's what you > should do too, they are quite explicit, even for newbies, and will > give you a good idea of what you need and what you don't. > Also, doing this will help you no being completely lost and confused > in front of your brand new system when you'll recieve it ! > > I don't know where you're from, but there's maybe someone or some shop > in your area who could demonstrate modular stuff for you and learn you > the basics. > > Buying a new system is an important decision to me and should be > prepared carefully, good luck ! > > ... and sorry for bad english ! > Max. > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed]
