Oberkorn issues with Doepfer case?
2007-06-14 by plastichorneddevil
Hello there, sorry to butt in with my personal problem, but I seem to have some sort of issue trying to put an Oberkorn sequencer in a Doepfer case. The sequencer just wont do its thing unless its plugged into my Analogue Systems case. Is there some sort of power issue hanging up the gate trigger doohickeys? clueless... thanks for your time! kelly
2007-06-14 by Bakis Sirros
probably, the oberkorn needs a +5volts supply that the
doepfer case does not have as standard, but the
analogue systems case has.
best regards,
Bakis.
--- plastichorneddevil <kellyborkert@hotmail.com>
> sequencer in a
> unless its plugged
> power issue
> clueless...
> kelly
[Doepfer_a100] group owner
http://www.myspace.com/interconnectedmusic
http://www.myspace.com/memorygeist
http://www.DiN.org.uk
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Be a better Heartthrob. Get better relationship answers from someone who knows. Yahoo! Answers - Check it out.
http://answers.yahoo.com/dir/?link=list&sid=3965454332007-06-14 by atuzzi
--- In Doepfer_a100@yahoogroups.com, "plastichorneddevil" <kellyborkert@...> wrote: > > Oberkorn sequencer in a > Doepfer case... yep, you need a 5 Volts miniconverter/adapter... look for "A-100AD5" in page http://www.doepfer.de/a100z_e.htm at
but only assuming that the Oberkorn needs only 100ma
in the +5volts supply.
it would be better to ask Tom Carpenter about the
+5volts current draw of the Oberkorn.
best regards,
Bakis.
> > Doepfer case...
> yep,
> look for "A-100AD5"
> in page
> at
Athens-Greece
Sick sense of humor? Visit Yahoo! TV's
Comedy with an Edge to see what's on, when.
http://tv.yahoo.com/collections/2222007-06-14 by plastichorneddevil
Thank you gentlemen! This sequencer appears to have some other issues I need to look into. Im going to get a voltage adapter this morning to see if it works properly in the 220v case it came with. I have had absolutely no problems with my A-155 sequencer, I just love it. It would be great if this unit performed as well in conjunction with the 155. I'll post again when Ive tried a few things to see whats going on. Gratefully, kelly --- In Doepfer_a100@yahoogroups.com, Bakis Sirros <synth_freak_2000@...> wrote: > > but only assuming that the Oberkorn needs only 100ma > in the +5volts supply. > it would be better to ask Tom Carpenter about the > +5volts current draw of the Oberkorn. > best regards, > Bakis. > > > > --- atuzzi <antoniotuzzi@...> wrote: > > > > > > > --- In Doepfer_a100@yahoogroups.com, > > "plastichorneddevil" > > <kellyborkert@> wrote: > > > > > > Oberkorn sequencer in a > > > Doepfer case... > > > > > > yep, > > > > you need a 5 Volts miniconverter/adapter... > > > > look for "A-100AD5" > > > > in page > > http://www.doepfer.de/a100z_e.htm > > > > at > > > > > > > Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist > [Doepfer_a100] group owner > http://www.parallel-worlds-music.com > http://www.myspace.com/parallelworldsmusic > http://www.myspace.com/interconnectedmusic > http://www.myspace.com/memorygeist > http://www.DiN.org.uk > http://www.shimarecords.co.uk > http://www.rubber.gr > Athens-Greece > > > > ______________________________________________________________________ ______________
> Sick sense of humor? Visit Yahoo! TV's > Comedy with an Edge to see what's on, when. > http://tv.yahoo.com/collections/222 >
