Doepfer
A-155 - how to start on first step after reset?
2007-06-12 by Florian Anwander
playing with my A-155 the last days the problem/question arose again:
If I do stop and reset. The reset jumps to step 1. The first clock after
start makes it to advance to step 2 with the first note.
Ok, I could think step 2 as first, but if I want to use the reset while
the sequence is running, it would not reset to 2 (the intended first
step), but to 1 (the technical real first step).
So what I need is some trick which suppresses the clock to advance the
counter with the first step.
I know how to do this by some logic and flip-flops, but I have no idea
how to achieve this with the means of the A-100 (and no, I do not want
to use a lot of A-166 to create flipflops).
Florian
Re: [Doepfer_a100] A-155 - how to start on first step after reset?
2007-06-12 by Silas Johansen
I don't think there's an easy solution to this problem, or at least not
using existing modules. I think the least hard way to get the effect that
you want is to send a reset pulse simultaneously with the first clock pulse.
You could use an A160 to make sure that the sequencer got a reset pulse
every 8/16/32 steps, thus ensuring that if you (re)started the sequence at
the beginning of a bar it would start from step one. Just don't
stop/reset/restart your A160...
I have plans to build my own sequencer in addition to the 155 I got. When I
do so I'm tempted to go with a design that will allow both reset to step one
and reset to last step on different reset inputs (& buttons) - I expect this
feature to make life a lot easier ;)
Silas
On 6/12/07, Florian Anwander <Florian.Anwander@consol.de> wrote:
>   Hi,
> Florian
Hi Silas
This was my first try, but it does not work. I even tried to delay the
reset trigger.
Florian
2007-06-12 by verstaerker
just a question- why don't u use an A-154 - it doesn't have this  problem
> Hi Silas
>  reset trigger.
>  Florian
Mit freundlichen Grüßen
verstaerker
mailto:verstaerker@verstaerker-music.net
2007-06-12 by Denis Gökdag
you could use a CV adressing the steps; draw a stepped controller
curve in your DAW sequencer.
only works for certain situations, though.
denis
> Hi Silas
> effect that
> clock pulse.
> reset trigger.
> Florian
Hi
Because I have no need of the (other) features of the A-154; and
spending extra 170 Euros for only to get a start/stop/reset behaviour
that I would expect by default?
Florian
good point ;)
> Hi
>  Florian
oh man, sorry, confused 155 and 154
> denis
> > Hi Silas
> > effect that
> > clock pulse.
> delay the
> > reset trigger.
> > Florian
AW: [Doepfer_a100] A-155 - how to start on first step after reset?
2007-06-12 by hardware@doepfer.de
> Hi,
> Florian
The problem has been solved with the A-154 as controller for the A-155. A
reset "prepares" the internal logic for the "real" reset. The advance to
step 1 takes place at the next clock pulse. But we already got some
complaints about this behaviour as the people are used to the behaviour
where a reset causes an immediate jump to step 1.
Best wishes
Dieter
Hi Denis
In german we call this: "shoot with a cannon to a sparrow".
And honestly: I try to avoid to switch on a computer when making music...
Florian
Then you could build your own counter module and replace the one in
the 155.
there are counter ICs that after receiving a reset pulse will wait
with incrementing their state untill they receive the next clock pulse .
this is obviously also a lot of work, but you could get an IC with up/
down selection for instance.
btw: surface-to-air missiles are a lot more effective against those
birds, believe it.... ;-)
denis
On 12. Jun 2007, at 4:45 PM, Florian Anwander wrote:
> Hi Denis
> music...
> Florian
Re: A-155 - how to start on first step after reset?
2007-06-12 by Adam-V
I have just installed an A-154 into my system and noticed similar
behaviour to that described in the initial post. If you hit reset
whilst the sequencer is running it will actually play step 2 as the
first note. I have heard that this is a problem with many sequencers
too though. The option to have reset to step 8 rather than step 1
would be really nice as this would alleviate this issue ensuring that
the next clock cycle advances to step 1.
Adam-V
problem
Re: [Doepfer_a100] Re: A-155 - how to start on first step after reset?
What???
My 154 just stops on the actual step and when i start again - it starts at One
also pressing reset during playback goes back to One
Do u probably have an old version of the 154!?
Adam-V
problem
verstaerker
It should be the latest version, I only received it from Doepfer on
Friday.
I'll have to double check the behaviour when I get home from work
tonight but I'm certain was mine starting at step 2 when reset was
pressed while the sequence was running. It does stay on the current
step when you press stop but I can't recall what happens if you then
press reset, I'll have to check this tonight too.
Adam-V
> What???
starts at One
> Cheers,
> Adam-V
> problem
> verstaerker
> mailto:verstaerker@...
2007-06-13 by Adam-V
OK I have had time to check this out and found the following:
With the A-154 in Forward mode, pressing reset causes the sequence to
start from step 1 on the next clock cycle if the sequence is running
or on the next press of the start button if it is stopped.
With the A-154 in Reverse mode, pressing reset causes the sequence to
start from step 8 on the next clock cycle if the sequence is running
I believe this is the correct and desired behaviour for both modes.
With the A-154 in Pendulum mode, pressing reset causes the sequence to
start from step 2 on the next clock cycle if the sequence is running
I would have expected the sequence to restart on step 1 as with the
forward mode.
Sorry if I confused anyone with my previous post but I knew I saw this
behaviour just the other day but I must have been running in pendulum
mode.
Adam-V
> Friday.
> Cheers,
> Adam-V
2007-06-13 by Florian Anwander
Hi
> first note.
I think, this is occasionally - its a question of timing.
You may check what happens if you feed the reset from a trigger out of
the A-155.
Yes, but again, the reset in runnning mode as described would cause a
step back to step 8 instead  of step 1.
Florian
Re: AW: [Doepfer_a100] A-155 - how to start on first step after reset?
2007-06-13 by verstaerker
i think it's a bit confusing for users that both devices react differently
what about a switch on both devices to switch between both behaviours
>  Best wishes
>  Dieter
verstaerker
2007-06-13 by hardware@doepfer.de
Denis,
very interesting. Can you tell me the name of this counter circuit. Maybe we
could do a redesign of the A-155 controller board. Now a CD4024 is used as
counter.
Dieter
AW: [Doepfer_a100] Re: A-155 - how to start on first step after reset?
As far as I remember the A-154 resets to the step defined by the "first
step" control. But I'm not 100% sure. Unfortunately I have no A-154/A-155
available to try it out. My complete demo system has been sold and I'm about
to arrange my new "private" system.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Adam-V
> Gesendet: Mittwoch, 13. Juni 2007 00:40
> Betreff: [Doepfer_a100] Re: A-155 - how to start on first step after
> reset?
> Cheers,
> Adam-V
> problem
AW: AW: [Doepfer_a100] A-155 - how to start on first step after reset?
I will see if there is a chance to add another switch to the A-154 but from
the first glance this will be a problem as there is no space at the front
panel left and all port inputs of the microcontroller are used. Maybe a
special control setting (e.g. first step fully clockwise) could be used to
trigger the second reset mode (i.e. immediate reset to step 1).
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von verstaerker
> Gesendet: Mittwoch, 13. Juni 2007 09:37
> An: hardware@doepfer.de
> Betreff: Re: AW: [Doepfer_a100] A-155 - how to start on first step after
> reset?
> the A-155. A
> advance to
> >  Best wishes
> >  Dieter
> verstaerker
Hi Dieter
we do not want to have this, because a reset while playmode would show
the same behaviour.
This "wait for second step"-behaviour should only be shown if the reset
comes while stop mode or at the didentical moment with the
start-trigger. I think this requires some RS-Flipflop work...
Florian
> Denis,
> counter.
> Dieter
Florian Anwander                  |ConSol
Tel.   +49(89)45841-133           |Consulting&Solutions Software GmbH
Fax    +49(89)45841-111           |Franziskanerstr. 38, D-81669 München
email: florian.anwander@consol.de |http://www.consol.de
Ok,
I think, I've got it:
The core is an RS-Flipflop, which is controlled at SET by the halftime
clock (dived by 2) and by the the Stop trigger at RESET. The Q-Out
controls an AND which enables the Clock:
Clock---------+------------------\
Start---Reset-x/2                \--AND
               |       ......        AND----Clock to seq-counter
               \-------.S  Q.--------AND
Stop------------------.R -Q.
Should work like that:
"Stop" resets the Q to low. This disables the Clock at the Sequencer
counter. Start resets the divider which diveds the clock. So the divided
clock is low. At the second clock pulse the divided clock becomes high
-> the high activates set, which enables the clok in the AND.
Florian
> Hi Dieter
> the same behaviour.
> Florian
>> Denis,
>> Maybe we
>> used as
>> counter.
>> Dieter
>> Yahoo! Groups Links
2007-06-13 by Stu Grimshaw
hi all,
pardon my butting in at this late stage but: the suggestion to reset to the last step seems
to have passed unnoticed. i'm looking at this from a slightly different perspective, in that
i'm only using a 160/161 combo, but the behaviour of the 161 is also a headache in this
respect.
the on/off status of the gates of the 160 is no more or less of an issue than if they were
reversed - depends what you're doing with them - but i think most users will probably
need the 161 to start on the first step after a stop/reset. a reset without the stop is a
different matter, of course, but i'll bet a quid that most of us use the reset after a stop
more often than during a run.
(except for those 5 and 7 step sequences, so:)
an a-161b which resets to step 8 would be a useful alternative for me. or better yet, a
jumper on the circuit board (ditto for the 154 and 155) to let the user decide i.e. no space
problems ?
sorry for the noobie stuff :)
stu
p.s. @ dieter: how about a bus connection on the 161 for a second 161 running from the
same 160 ?
Hi Stu
The most simple way is: use socket 8 as 1, socket 1 as 2 and so on. No
b-version module required.
> same 160 ?
You can diy it: its simply pressing a second connector on the flat
cable. No soldering required.
Florian
2007-06-14 by hardware@doepfer.de
running from the same 160 ?
That's easy. You simple need a 10 pin cable with 3 female connectors (one
for the A-160, one for A-161 #1 and one for A-161 #2).
But I cannot see an application for this purpose. The outputs of the second
A-161 would be a 1:1 copy of the first one unless you use different clocks
or resets for the two units. But this requires some DIY as mentioned in one
of my former messages.
Best wishes
Dieter
2007-06-14 by Stu Grimshaw
@ dieter: that's more or less what i'm looking at - bending the 160/161 to run from a
subdivision of the input to the 160, i.e. one of the 160's outputs. if i can manage that,
then i'd like to try to get two 161s running at different speeds.
if i can reset them separately too - thanks for your post on this - then i can have them in
different time signatures too.
all of which would give me a pretty flexible sequencer combo for just 12TE, more so if i
add a vcs to it.
stu
> Best wishes
> Dieter
Please look at my message from June 04, 2007 for details.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Stu Grimshaw
> Gesendet: Donnerstag, 14. Juni 2007 15:47
> reset?
> add a vcs to it.
> stu
> connectors (one
> of the second
> different clocks
> mentioned in one
> > Best wishes
> > Dieter
2007-06-14 by Florian Anwander
Hi Stu
> add a vcs to it.
I don't have the schemoes of the A-161 here, but I had a look at it
yesterday evening. The A-161 is based on a CD-4017 Chip
(eg.
http://pdf1.alldatasheet.com/datasheet-pdf/view/50846/FAIRCHILD/CD4017.html)
Clock in is pin-14 of the chip and reset in is pin-15
As far as I remember the ribbon cable from the A-160 to the A-161 feeds
clock on wire-1, reset on wire-2, inverted clock on wire-3, and inverted
reset on wire-4. The rest is ground and Supply voltage
You have to split this connection between the ribbon cable and the chip,
insert a socket and connect the socket via a transistor/resistor combi
like the following to the counter (should be done for both: clock and reset)
                       +12 V
                         R
                         R 10k
                         R
               100    |C
from socket---RRRR--B|   BC549
                      |E
                         +--------to-CD4017
                         R
                         R 1k
                         R
                      Ground
Assumingly you need an additional frontplate to have place for the
additional sockets.
All written from memory, no guarantee that it will work. ;-)
