Doepfer
A-112 Help?
A-112 Help?
2007-08-13 by junglephone
Okay so I've recently acquired a nice little A-100 system and am
having a blast with the synthesis aspect. However, I am stymied by the
A-112. I just can't seem to perform a MIDI sample dump into the
module. I have read the manual many times but I seem to have a mental
block about this particular procedure. Add to that the fact that I am
using a PPC G5 Macintosh computer so I can't use the Doepfer or Wiard
utilities, and I seem to be at an impasse.
I have done and continue to do extensive sample editing in Bias Peak
and so I have quite a library to pick from. I have a Novation Remote
the A-190. I have tried plugging the thru of the A-190 to the in of
the A-112...nothing. I have tried plugging the out from the Novation
directly into the A-112...nothing. Peak will not recognize the A-112
as a dump destination. I also have Elektron's C6 utility which
performs the dump but nothing winds up in the A-112. FYI, I also have
Live 6 and Logic Pro 7.2.
I would really like to make this work but I am clearly not
understanding the manual. I'm wondering if anyone is successful
performing sample dumps to and from the A-112, to and from a PPC
Macintosh. If so, I'd certainly appreciate some assistance.
Adam
AW: [Doepfer_a100] A-112 Help?
2007-08-14 by hardware@doepfer.de
> Thanks,
> Adam
You have to set the second switch of the A-112 to the left position (Dmp)
and wire the Midi In and Out to the Midi interface of your computer in the
right way. The rest has to be done by the software of the computer. Only if
the second switch is in the Dmp position a Midi dump from/to computer is
possible. Sorry - I have no experience with Macs.
Best wishes
Dieter Doepfer
