voltage attenuation and offset questions
2007-08-15 by rafe127
Hi, So lets say I have a theremin module A178 and I want the entire range of control of the theremin to only affect one octave of pitch. I imagine I can do this with a A129-3 via attenuation and offset, is that correct? If the output of the theremin ranges over 5 volts normally (is this true?) then if I attenuate it it will range over only 1 volt.... I hope. Then I can offset the output so that the volt in question will correspond to the octave of my choice. Is this all accurate? Is this the best way to do this? I think maybe it is also possible with the A138c using the offset function of input one. Please let me know, thanks, Rafael
