On the A-137 page there are some green/black figures demonstrating
control setting effects. They seem to be real oscilloscope captures,
as I was able to reproduce them with reasonable accuracy. So, my A-
137 seems to work normally.
Some observations (and some might think nit-picking):
- Of the above mentioned figures "Changing the Symmetry"
and "Changing the Harmonics" pictures are swapped.
- The above mentioned figures are said to demonstrate: "changing a
control from low (left picture) to high (right picture)". This
doesn't necessarily translate to from full counter clockwise to full
clockwise - at least in my unit.
- It is best to start experimenting with Harmonics at 9'o clock or
more. First I assumed, that full counter clockwise was somewhat
neutral setting.
- The Harmonics control works "a little bit like the resonance
control of a filter". It doesn't sound at all like a filter though.
- The diagrams in the manual showing some triangle wave folding are
indeed diagrammatic. I can't reproduce them.
Best regards
Jari Jokinen
--- In Doepfer_a100@yahoogroups.com, "Tim Stinchcombe" <timothy@...>
wrote:
> Hi Jari,
> At roughly the same settings as you give, my A-137 gives a very
> similar trace to yours. Because of the 4 stages acting one after
> other, it is quite hard to see the effect of each stage and/or
> controls in isolation. I suspect the diagrams in the manual are
> rather diagrammatic of what is going on, rather than the literal
> truth, but I'll study the circuit a little, and see if I can answer
> some of your other questions.
> Tim
> --- In Doepfer_a100@yahoogroups.com, "jalmari3" <jari.jokinen@>
> wrote:
> > I can't duplicate the folded triangle waveforms shown in the A-
137
> > manual (chapter 2). The shown waveforms consist of straight
lines,
> but
> > I get rounded waveforms.
> > Here is an example oscilloscope view:
> > http://www.esnips.com/doc/278f44e2-ce2a-4ff1-8f17-1f7ef5d795d7/A-
> > 137_weirdness_1
> > (I hope the link isn't too long for Yahoo.)
> > The settings are:
> > - All CV inputs at full counter clockwise and unplugged
> > - Input level at 12'o clock
> > - Multiples at 9'o clock
> > - Folding level at 12'o clock
> > - Symmetry at 12'o clock
> > - Harmonics at full counter clockwise
> > Questions:
> > - Is this the expected output on these settings
> > - Why does a triangle input get rounded?
> > - What settings should give the straight line waveforms shown in
> the
> > manual?
> > Best regards and thank you for your time
> > Jari Jokinen
