bassiest doepfer low pass?
2007-10-05 by Carlos
Which of the low pass filters produces the deeper sounding most terrifying bass sounds? thinking about both when sequencing in self oscillation, but in general as well...
2007-10-06 by Florian Anwander
Hi Carlos > Which of the low pass filters produces the deeper sounding most > terrifying bass sounds? > > thinking about both when sequencing in self oscillation, but in > general as well... Its not the filter, which gives the bass, its the oscillator. Use sine and saw at the same time. The sine will nail your stomach to the wall. Florian
2007-10-07 by vliesgaard
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <Florian.Anwander@...> wrote: > > Hi Carlos > > > > Which of the low pass filters produces the deeper sounding most > > terrifying bass sounds? > > > > thinking about both when sequencing in self oscillation, but in > > general as well... > Its not the filter, which gives the bass, its the oscillator. Use sine > and saw at the same time. The sine will nail your stomach to the wall. > > Florian > I think what is being meant is filter growl.
2007-10-07 by ilanode
Does this count? "[A] second audio feedback path to boost bass response at higher Q levels. This makes the filter "growl and rumble" even more!" Paul S. on the MOTM-440 VCF. The MOTM-440 is inspired by the SSM2040 chip and I *guess* the A105 (which is based on the SSM2044) is similiar in design. Anyhow, I was never able to give the MOTM-440 a listen but the A105 is impressing. --- In Doepfer_a100@yahoogroups.com, Florian Anwander <Florian.Anwander@...> wrote:
> > Hi vliesgaard > > > I think what is being meant is filter growl. > What is "filter growl" (technically spoken)? > > Florian >
2007-10-07 by Florian Anwander
Hi vliesgaard > I think what is being meant is filter growl. What is "filter growl" (technically spoken)? Florian
2007-10-08 by vliesgaard
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <Florian.Anwander@...> wrote: > > Hi vliesgaard > > > I think what is being meant is filter growl. > What is "filter growl" (technically spoken)? > > Florian > I don't realy know, but I'll try to give a defenition: The amount of musical distortion the filter produces. 2 extreme examples: Minimoog filter a bit overdriven has a nice warm creamy character when you turn the cutoff knob. This makes the sound warm and bassy A cheap digital filter, witch produces hardly any distortion. And sounds therefore a bit less warm than a minimoog filter.
2007-10-08 by Florian Anwander
Hi vliesgaard >>What is "filter growl" (technically spoken)? > The amount of musical distortion the filter produces. > > 2 extreme examples: Minimoog filter a bit overdriven has a nice warm > creamy character when you turn the cutoff knob. This makes the sound > warm and bassy > A cheap digital filter, witch produces hardly any distortion. And > sounds therefore a bit less warm than a minimoog filter. Ok, this will not be achieved by the filter itself, but by an level change before the filter. You also might decrease the input resistor for the audfiosignal (which would be the same). More interesting is the answer of Ingo (ilanode). Florian
Hi Ingo > Does this count? "[A] second audio feedback path to boost bass > response at higher Q levels. This makes the filter "growl and rumble" > even more!" Paul S. on the MOTM-440 VCF. > > The MOTM-440 is inspired by the SSM2040 chip and I *guess* the A105 > (which is based on the SSM2044) is similiar in design. Anyhow, I was > never able to give the MOTM-440 a listen but the A105 is impressing. Ok, now we come closer: An increased resonance means, the output voltage of audio signals at the cutoff frequency is increased in comparison to the signals at lower frequncies than the cutoff frequency (speaking only for lowpass filters now). Now there the question is how the filter behaves regarding its complete outputsignal. Several types are possible: 1.) The maximum output voltage of the signal stays the same, which means signals below the cutoff frequency (and below the resonance peak) will have a lower signal level - in other words: There will be less bass with higher resonance. 2.) The output voltage of signals below the cutoff frequency will stay the same, which means the resonance "peak" will have a higher voltage. With other words: higher resonance won't touch the bass. BUT: This will usually cause distortion in the following audio path, because the resonance peak will. This is generally unwanted (and no filter is really designed like that). It could be achieved by simply using an amplification after the resonating filter. 3.) the overall power[*] of the output signal stays the same. This means also that the low frequencies will have a reduced output level (as in 1), but the amount of reduction depends of the resonance frequency: a high frequency in resonance will have less electrical power and will reduce the overall power less than a low frequency in resonance (I hope this description is not too confusing). Dieter once explained to me, how one can determine in the schematic which type of resonance is used, but I don't remember it. To my knowledge the A-122 and A-123 are of type 1, the A-105 is type 3, the A-120 and other non-single-chip-filters are somewhere inbetween type 1 and 3. I don't know about the A-121 (but for 12dB filters this issue is less relevant as for 24dB filters). So I think, the A-105 is the filter that Carlos asked for. For an A-122/123 one could use a CV to control the resonance; the same CV should control also the signal level in a following VCA (with less control amount). This might compensate the level loss at higher resonance settings. Florian [*]we remember physics lessons when we were 14 years old ;-): electrical power is product of voltage and current
Hi Ingo > The MOTM-440 is inspired by the SSM2040 chip and I *guess* the A105 > (which is based on the SSM2044) is similiar in design. Anyhow, I was > never able to give the MOTM-440 a listen but the A105 is impressing. Nope, 2044 and 2040 are quite different chip designs. Florian
2007-10-08 by Carlos
I guess I didnt word my message to well. yes which filter has the most 'growl' but also sounds good and bassy when set to self oscillate --- In Doepfer_a100@yahoogroups.com, "vliesgaard" <vliesgaard@...> wrote: > > --- In Doepfer_a100@yahoogroups.com, Florian Anwander > <Florian.Anwander@> wrote: > > > > Hi Carlos > > > > > > > Which of the low pass filters produces the deeper sounding most > > > terrifying bass sounds? > > > > > > thinking about both when sequencing in self oscillation, but in > > > general as well... > > Its not the filter, which gives the bass, its the oscillator. Use sine
> > and saw at the same time. The sine will nail your stomach to the wall. > > > > Florian > > > I think what is being meant is filter growl. >
The A-108 is most like the minimoog. I think.
2007-10-08 by jilt@robotfunk.com
Could it be the original poster is just looking for a very steep filter, say 24 dB/oct or higher? The steeper the slope, the more resonance around the cutoff frequency. Jilt van Moorst www.robotfunk.com
2007-10-08 by Anthony Rolando
>You also might decrease the input resistor for > the audfiosignal (which would be the same). Depending on the design, changing the audio signal input resistor could also affect input impedance. This will greatly affect the tone of the signal before entering the filter, and probably not in a way that most people would appreciate. Tony > To: Doepfer_a100@yahoogroups.com > From: Florian.Anwander@consol.de > Date: Mon, 8 Oct 2007 11:36:41 +0200 > Subject: Re: [Doepfer_a100] Re: bassiest doepfer low pass? > > Hi vliesgaard > > >>What is "filter growl" (technically spoken)? > > The amount of musical distortion the filter produces. > > > > 2 extreme examples: Minimoog filter a bit overdriven has a nice warm > > creamy character when you turn the cutoff knob. This makes the sound > > warm and bassy > > A cheap digital filter, witch produces hardly any distortion. And > > sounds therefore a bit less warm than a minimoog filter. > Ok, this will not be achieved by the filter itself, but by an level > change before the filter. You also might decrease the input resistor for > the audfiosignal (which would be the same). > > More interesting is the answer of Ingo (ilanode). > > Florian > > > > Yahoo! Groups Links > > > _________________________________________________________________ Boo! Scare away worms, viruses and so much more! Try Windows Live OneCare! http://onecare.live.com/standard/en-us/purchase/trial.aspx?s_cid=wl_hotmailnews [Non-text portions of this message have been removed]
Hi Anthony > Depending on the design, changing the audio signal input resistor could also affect input impedance. This will greatly affect the tone of the signal before entering the filter, and probably not in a way that most people would appreciate. Thats true in principle, but not for combinations of doepfer modules. Florian
Hi Carlos > I guess I didnt word my message to well. yes which filter has the most > 'growl' but also sounds good and bassy when set to self oscillate OK - if I understand growl right (that what a Fender Jazzbass can give), then still it is NOT the filter - its the oscillator waveform. Quite nice examples are the darker synth basses of Steve Winwood, or bass of Bernard Edwards in "Your love so good to me" (yes, the bass player of Chic did one of the greatest synth bass licks I know - and sorry for these boring old fart examples). Try this: 1.) Three VCOs, one with asymetric, not modulated pulsewave is very dominating, the others are saw and triangle but each of them gives maybe only 10% of the signal. 2.) lot of small manual given vibratos from the modulation wheel. 3.) Lowpassfilter (no matter which one) with only a little(!) envelope amount, little resonance; filter envelope is more a longer and piano like envelope. 4.) VCA envelope may be organ or long piano style but without release. 5.) Put some fat and nasty compressor on it (Edwards used a Urei 1176). Now switch the compressors bypass on and off, and you will see, that especially the compressor raises the "growl" which basically was produced by the asymmetric pulse beating a littlebit with of the other low leveled VCOs. Florian
sounds good will try it out, though I don't own a compressor. but I still need to choose a low pass filter for my doepfer portable system :) someone mentioned the a-105 is similar to the motm 440 I have that motm filter on my studio system (mix of .com, motm, and modcan) and is my favorite filter I own, so that might be the ticket, I am also intrigued by the a-102 though as it seems like you can get some nicely extreme sounds out of it and I don't own any diode based filters. I might end up getting both, but like I said, I am building a doepfer portable system, so trying to minimize on extra filters/etc. Carlos --- In Doepfer_a100@yahoogroups.com, Florian Anwander <Florian.Anwander@...> wrote: > > Hi Carlos > > > I guess I didnt word my message to well. yes which filter has the most > > 'growl' but also sounds good and bassy when set to self oscillate > OK - if I understand growl right (that what a Fender Jazzbass can give), > then still it is NOT the filter - its the oscillator waveform. > > Quite nice examples are the darker synth basses of Steve Winwood, or > bass of Bernard Edwards in "Your love so good to me" (yes, the bass > player of Chic did one of the greatest synth bass licks I know - and > sorry for these boring old fart examples). > > > > Try this: > 1.) Three VCOs, one with asymetric, not modulated pulsewave is very > dominating, the others are saw and triangle but each of them gives maybe
> only 10% of the signal. > 2.) lot of small manual given vibratos from the modulation wheel. > 3.) Lowpassfilter (no matter which one) with only a little(!) envelope > amount, little resonance; filter envelope is more a longer and piano > like envelope. > 4.) VCA envelope may be organ or long piano style but without release. > 5.) Put some fat and nasty compressor on it (Edwards used a Urei 1176). > > Now switch the compressors bypass on and off, and you will see, that > especially the compressor raises the "growl" which basically was > produced by the asymmetric pulse beating a littlebit with of the other > low leveled VCOs. > > Florian >
2007-10-09 by Ken
I have the A-105... I was looking for meaty bass heavy sounds for Drum N'Bass and Dubstep.. big growly bassy sounds. I like the A-105 a lot for this. It has a smooth character at lower settings but if you raise the input gain past about 9 O'Clock it starts to get a little gritty. I usually use either 3 saws or 2 Squares... and then just wobble it :)
2007-10-09 by vliesgaard
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <Florian.Anwander@...> wrote: > > Hi Carlos > > > I guess I didnt word my message to well. yes which filter has the most > > 'growl' but also sounds good and bassy when set to self oscillate > OK - if I understand growl right (that what a Fender Jazzbass can give), > then still it is NOT the filter - its the oscillator waveform. > > Quite nice examples are the darker synth basses of Steve Winwood, or > bass of Bernard Edwards in "Your love so good to me" (yes, the bass > player of Chic did one of the greatest synth bass licks I know - and > sorry for these boring old fart examples). > > > > Try this: > 1.) Three VCOs, one with asymetric, not modulated pulsewave is very > dominating, the others are saw and triangle but each of them gives maybe > only 10% of the signal. > 2.) lot of small manual given vibratos from the modulation wheel. > 3.) Lowpassfilter (no matter which one) with only a little(!) envelope > amount, little resonance; filter envelope is more a longer and piano > like envelope. > 4.) VCA envelope may be organ or long piano style but without release. > 5.) Put some fat and nasty compressor on it (Edwards used a Urei 1176). > > Now switch the compressors bypass on and off, and you will see, that > especially the compressor raises the "growl" which basically was > produced by the asymmetric pulse beating a littlebit with of the other > low leveled VCOs. > > Florian > Great patch example. I tried it with a wasp filter, a morfing filter and a system 100 filter. The difference between the filters is quite noticable. The wasp sounds airy, the sys 100 blows the glass out of the window, the morfing filter is in between. Filters sound different, some are more creamy than others. I think, the topic starter just wants to know what filter has the nicest distortion character.
2007-10-09 by Florian Anwander
Hi Carlos > sounds good will try it out, though I don't own a compressor. Then its definitely to get one ;-) I always recommend the Alesis smashup from the ModFX Series. They go for a few bucks (~ $30) on ebay and they sound incredible good for this price. The next quality step would be at the $800 range. > but I still need to choose a low pass filter for my doepfer portable > system :) Go for the A-105. Florian
