> hello
> I just got the 2046 stage bbd module. when i first had it going,
> the delay clock knob seemed
> to have a far more drastic effect on the range of the hsvco. for
> some reason the range is
> much tighter now and at the lowest setting im not getting that
> crunchy long delayed effect.
> is there an adjustment i can make to increase the range of the knob?
> thanks!
Sounds like a defective exponential converter of the HSVCO. I suppose that
one of the transistors in the transistor array of the converter is damaged.
This would explain the reduced frequency range. If you are able to replace
an integrated circuit (no soldering required, justed removing the circuit
from the socket and replacing it by a new one) we would send a new
transistor array to your dealer/representative for free.
Best wishes
Dieter Doepfer
