Doepfer
Can the A-100 and Ableton Live play nice?
2008-01-10 by junglephone
Hello All,
I am attempting to play the A-100 with the Ableton Live 7 arpeggiator. It works except
that at random points, there is a "hiccup" in the rhythmic flow.
I tested the arp with sofsynths and had no problems.
I have played with the A-140 to see if it effects the timing.
I have sent the gate from the 190 straight to the vca.
I have played with the buffer settings in Live. My MOTU 828 mkII is synced to an Apogee
Big Ben so one would think audio is rock solid. (PPC Mac DP 2.0G, OSX 10.4.11)
Am I missing something?
Nothing useful from the Ableton forums yet. I know this isn't a DAW forum but....
Any ideas, fixes, etc. would be most appreciated.
Thanks in advance.
Adam G
Re: Can the A-100 and Ableton Live play nice?
Thanks for the response!
It's not that steps are dropping out because of a note range issue. I'm getting all the notes
I play. It's that the rhythmic timing of the stream of notes (16th notes for instance)
glitches at random moments. In other words, the timing is not solid.
Thanks again,
Adam G
--- In Doepfer_a100@yahoogroups.com, verstaerker <verstaerker@...> wrote:
> i encountered that the my a-190 is only accepting notes not lower than
> C3 (if i remember right) for trigger  - this can be adjusted in the
> config (see manual)
> > Hello All,
except
Apogee
> > Thanks in advance.
> > Adam G
I really appreciate you taking the time to respond.
I'll try it.
> i just thought that might be the reason - i'll check that tonight
notes
> > Thanks again,
> > Adam G
> >> config (see manual)
> >> > Hello All,
> > except
> > Apogee
> >> > Thanks in advance.
> >> > Adam G
Re: [Doepfer_a100] Can the A-100 and Ableton Live play nice?
2008-01-10 by verstaerker
config (see manual)
> Hello All,
> Thanks in advance.
> Adam G
Re: [Doepfer_a100] Re: Can the A-100 and Ableton Live play nice?
> Thanks again,
> Adam G
>> config (see manual)
>> > Hello All,
> except
> Apogee
>> > Thanks in advance.
>> > Adam G
Understood. This is a very plausible explanation.
I'm trying to find a way to filter MIDI data in Live but so far, nothing.
I created a template in the Novation with no Aftertouch hoping that would help but it
didn't.
I'm starting to think a more robust MIDI to CV might be in order? (Sorry Dieter ;-))
Adam G
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <Florian.Anwander@...>
wrote:
> Uuups
> > I could imagine that this is an delay caused by an high of the A-190s
> The word "load" is missing here. This should read like:
> ....that this is an delay caused by a high load of the A-190s MIDI
> buffer due to an large amount of incoming MIDI messages.
> Florian
2008-01-10 by Maxime
I'm not a pro with it, but the (aweomse) freeware "midi-ox" can
probably help you filtering and monitoring the midi datas you're
sending to your A190. There's a link at the bottom of the main
Doepfer.de webpage for download.
Hope that helps !
Max.
--- In Doepfer_a100@yahoogroups.com, "junglephone" <junglephone@...>
nothing.
would help but it
> didn't.
(Sorry Dieter ;-))
> Thanks,
> Adam G
<Florian.Anwander@>
> wrote:
> > Uuups
A-190s
> > Florian
2008-01-10 by Florian Anwander
MIDI buffer by an large amount of MIDI messages. I don't have a A190 but
I know similar behaviour from other MIDI-CV interfaces (e.g. the
MS-101), or from old MIDI-synths. Usually these delays it do not stand
out, but the regular rythmic structure of arpeggios makes them "visible".
You should check that no other ableton track/element sends to this
MIDI-Port - also for other MIDI-Channels.
Florian
Uuups
Florian
Re: Can the A-100 and Roland MC-4 play nice?
2008-01-10 by Adam-V
Hi Dave,
the MC-4 output levels are as follows:
CV: 0-10.4V (1V/O)
Gate/MPX: 0V off 12V On
Ext Sync output 0-5V
So, I reckon there should be no problems.
I haven't used my MC-4 that much since I picked it up, only to give it
a bit of a test but it seemed to work fine for me except I couldn't
get it sync to an LFO or the clock from the A154/155. Syncing the
A-154/155 to the MC-4 clock did work though.
Adam-V
--- In Doepfer_a100@yahoogroups.com, David Bulog <d2ba@...> wrote:
> Hi are the voltages out of the Roland MC-4 safe to use on the A-100
> modules
> Thanks Dave
Hi Adam
No ther is no (but the Sync setting in the preferences)
> didn't.
I don't think it is the interface. It is MIDI (internal softsynths are
controlled by very faster APIs). Try to connect only the a190 to this
MIDI-port (not channel! Port!). And then check your arpeggio.
It is also well known, that the MIDI timing of ableton is not the best
until Version 6.x. Its told that the new Version7 is much better in MIDI
timing than the older ones.
Florian
Florian, thanks.
I'm running Live 7 and the A100 is alone on its port.
I started using Live's external instrument plug-in (with the arp going into it) to trigger the
A100 and I have noticed some improvement but not a total fix. Fortunately I can fix the
timing of the audio file in Live later. If anyone else has any ideas, please keep them
coming. I'd like to solve this issue once and for all. The only rhythm glitches I want are
ones I intend, ya dig?  :-)
Thanks everyone.
Adam G
wrote:
> Hi Adam
> > didn't.
> Florian
Re: [Doepfer_a100] Re: Can the A-100 and Roland MC-4 play nice?
2008-01-11 by David Bulog
Thanks Adam
I received my MC4 yesterday so I letting it climate adjust for a few
days before powering up
I cant wait to try out--do you prefer the A154/155 over the MC4?
thanks Dave
On 11/01/2008, at 10:25 AM, Adam-V wrote:
> Hi Dave,
> CV: 0-10.4V (1V/O)
> Cheers,
> Adam-V
> > modules
> > Thanks Dave
2008-01-13 by Adam-V
Hi dave,
In my opinion, they're both great sequencers and the A-155 finds it
way into nearly every one of my patches but they do excel in different
areas.
The A-154/155 is far more immediate and more useful for experimenting
as you can just twist the knobs until you get something you like.
The MC-4 is not as immediate in that you can't really adjust it in
real time; you actually need to program it step by step which can be a
bit difficult given that you need to know which numbers represent
which notes and punch them into the keyboard (I've yet to experiment
with the CV record function) but it does have 2 CV outs on each of the
4 channels and the ability to save sequences is an obvious benefit. On
that, you can actually use a portable MD or MP3 recorder such as a
Zoom H4/H2 or similar instead of a tape recorder to save your
sequences. The MP3/ATRAC encoding doesn't cause any issues - you just
need to get your levels right.
If you've got any other questions about the MC-4 I'm more than happy
to answer them if I can. Just shoot me an email.
Adam-V
> Thanks Adam
> thanks Dave
> > Hi Dave,
> > CV: 0-10.4V (1V/O)
> > Cheers,
> > Adam-V
> > > modules
> > > Thanks Dave
2012-11-29 by prikolov
Hi there
since you got the topic, maybe you'd know the answer to my problem
i use live 8 with a100 through a190 and i actually don't get how the clock of a190 work. it runs wild and out of sync (tryed to divide it with a160 - still out of sync). i do send my sync messages from live. want that clock, so i could run sequenser using live's timing.
am i being too silly and not understanding something obvious?
Ilja
--- In Doepfer_a100@yahoogroups.com, "junglephone" <junglephone@...> wrote:
> Florian, thanks.
> Thanks everyone.
> Adam G
> --- In Doepfer_a100@yahoogroups.com, Florian Anwander <Florian.Anwander@>
> wrote:
> > Hi Adam
> > > didn't.
> > Florian
2012-11-29 by Bakis Sirros
hi Ilja,
the midi clock is not very accurate when syncing the A100 with the Ableton Live.
it helps if you have to use the reset out of the A190, patched to the reset input of the A154+a155 too.
but, again, sometimes the A100 seems synced to midi and sometimes not.
(its a problem of the midi clock, not of the A190)
the best syncing you can get via two cv/gate to midi channels. ( i use the MCV24 for this) :
you create a pattern of 16th notes in a channel of Live and the note gate out from that midi channel, you send it to the clock input of your modular sequencer (A155 for example).
then you create a pattern with one note at its very beginning, in another midi channel and you send the note gate from that channel to the reset input of your sequencer. (you can arrange the 'clocking' notes and the 'resetting' note just as you like!) rock solid timing and plenty of crazy clocking and resetting possibilities too. works fine all the time.
(Ingo Zobel gave me that simple and great tip, many years ago...)
thanks,
Bakis.
Sent: Thursday, November 29, 2012 4:09 AM
Subject: [Doepfer_a100] Re: Can the A-100 and Ableton Live play nice?
Hi there
Ilja
> Florian, thanks.
> Thanks everyone.
> Adam G
> wrote:
> > Hi Adam
> > > didn't.
> > Florian
2012-11-29 by Os
Better yet, ditch MIDI altogether.
e.g.
http://expert-sleepers.co.uk/silentway.html
http://expert-sleepers.co.uk/hardware.html
http://www.innerclocksystems.com/New%20ICS%20Lab%20Series.html
cheers,
os.
On 29 November 2012 11:19, Bakis Sirros <synth_freak_2000@yahoo.com> wrote:
> hi Ilja,
> Live.
> MCV24 for this) :
> thanks,
> Bakis.
> From: prikolov <prikolov@yahoo.com>
> Hi there
> Ilja
>> Florian, thanks.
>> I can fix the
>> please keep them
>> glitches I want are
>> Thanks everyone.
>> Adam G
>> wrote:
>> > Hi Adam
>> > > nothing.
>> > > would help but it
>> > > didn't.
>> > > (Sorry Dieter ;-))
>> > Florian
os@collective.co.uk
http://twitter.com/expertsleepers
http://www.darkroomtheband.net/
http://www.expert-sleepers.co.uk/
2012-11-29 by Jim Credland
Some midi interfaces are worse than others for timing.  Os has sample accurate solution - rocks.
Sent from my fone
> e.g.
> cheers,
> os.
>> hi Ilja,
>> Live.
>> MCV24 for this) :
>> thanks,
>> Bakis.
>> Hi there
>> Ilja
>>> Florian, thanks.
>>> I can fix the
>>> please keep them
>>> glitches I want are
>>> Thanks everyone.
>>> Adam G
>>> wrote:
>>>> Hi Adam
>>>>> nothing.
>>>>> would help but it
>>>>> didn't.
>>>>> (Sorry Dieter ;-))
>>>> Florian
> os@collective.co.uk
2012-12-01 by prikolov
Thank you everybody
you've been mighty resourceful
helped alot
Ilja
> Sent from my fone
> > e.g.
> > cheers,
> > os.
> > On 29 November 2012 11:19, Bakis Sirros <synth_freak_2000@...> wrote:
> >> hi Ilja,
> >> Live.
> >> MCV24 for this) :
> >> thanks,
> >> Bakis.
> >> From: prikolov <prikolov@...>
> >> Hi there
> >> Ilja
> >> --- In Doepfer_a100@yahoogroups.com, "junglephone" <junglephone@> wrote:
> >>> Florian, thanks.
> >>> I can fix the
> >>> please keep them
> >>> glitches I want are
> >>> Thanks everyone.
> >>> Adam G
> >>> wrote:
> >>>> Hi Adam
> >>>>> nothing.
> >>>>> would help but it
> >>>>> didn't.
> >>>>> (Sorry Dieter ;-))
> >>>> Florian
> > os@...
> > Yahoo! Groups Links
