Doepfer
A-111 High End VCO
A-111 High End VCO
2008-01-23 by David Westling
Hello group,
    I've got this A-111 I got used via AH some months ago.  it works
according to what I'd expect except that the range switch has an
anomaly.  Set all the way counterclockwise, it puts out at LFO
frequencies, but for the top two positions it reverts back to LFO. It
has ten positions also, not eight.  At the high end, nothing above
maybe 8000 cps is available.  And in the low end, it doesn't go all
the way down to less than 1 cps like other oscillators, but maybe to
five or six cps only.   Can anybody diagnose this?
David Westling
Re: A-111 High End VCO
2008-01-23 by Tim Stinchcombe
Hi David,
It
That sounds normal: only 8 of the ten 10 positions are used, and
because of the type of switch used (it is a 'binary coded decimal'
one), when you turn it past position 8, it 'wraps around' giving the
lower two settings again for 9 and 10.
In normal adjustment, the '-3' setting should give approx 8Hz with 0V
CV in, and the '4' position will then be 1046Hz, at 0V in. At '4', if
you input 5V, it should be good for 33kHz or so, and maybe more for
more volts in. If you are not getting this, then the irst step would be
to try and re-calibrate the module, which most likely you will need to
ask Dieter for!
Tim
