> There is a fuse in the black power receptacle on the back of the case,
> but you need to look closely to find it/to work out how to prise it
> open.
> The type and rating of fuse to replace it with depend on what voltage
> you are on: Dieter gave all the details in message #3773.
> In addition there is a high probability that the module powered the
> wrong way will be damaged in some way :-(
> Tim
> --- In Doepfer_a100@yahoogroups.com, "mombanu" <mombanu@> wrote:
> > i recently dismantled my a-100 in order to transport it. upon
> > reassembly, i must have put the power lead for one of the modules in
> > the wrong way. the a-100 went crazy for a few , then stopped working.
> > it won't power up anymore. is there a cheap and easy solution to this,
> > or will i have to buy a new power supply?
> > cheers
