RE: [Doepfer_a100] Am I very dense here?
2002-04-25 by Rhen, Kris
That is correct. Normally, modules that don't use +5v don't even connect anything to those pins on their cable. Its just totally unused. They all use the +-12v stuff though, and GND of course. Later KRIS > -----Original Message----- > Great Kris, thanx for the help, so if I understand you > right... using the > converter I can plug in both 12v modules and 5v modules on the same > busboard, right? > > > ----- Original Message ----- > > The bus board looks like this > > > > pin 1: -12V > > pin 2: GND > > pin 3: GND > > pin 4: GND > > pin 5: +12v > > pin 6: +5v > > pin 7: Bus CV > > pin 8: Bus Gate > > > > Normally, the power supply ONLY supplies the first and > fifth pins (as well > > as the three ground pin sets) and nothing is put on pin 6, > so normally > there > > is no 5v supply. > > > > When you put a 5v converter on the bus, what it does is this: > > > > pin 1: -12V > > pin 2: GND > > pin 3: GND > > pin 4: GND +---------------------------+ > > pin 5: +12v >>>>---| 5v regulator converts 12v | > > pin 6: +5v <<<<---| to 5v and puts back on bus| > > pin 7: Bus CV +---------------------------+ > > pin 8: Bus Gate > > > > (sorry for the ascii art - look at it with a proportional > font and it > should > > be OK) > > > > so all the guts needed to generate 5v from +12v are on the > little adapter > > (made up of an LM7805 3-pin chip like THIS: > > > > http://www.hep.upenn.edu/SNO/daq/parts/lm7815.pdf > > > > basically it takes +12v OFF of the bus (taps into it NOT removes it > > entirely, the +12v is still there, but the +5v adapter uses > some of its > > current to 'MAKE' +5v) and then it puts the appropriately > regulated +5v > BACK > > ONTO the bus, so in the end, you have all three voltage > sources on the > bus. [Non-text portions of this message have been removed]
