Hi Jason,
Interesting challenge! I did some quick calcs: say the note C at
highest range setting (=4) of A-111 is 2093Hz (if I?m an octave out,
then just +/- 1V as appropriate), then to get 14000Hz, input voltage
is 2.74V, and for 14200Hz it?s 2.76V ? that leaves just 0.02V=20mV to
play with! For comparison, a standard semitone?s worth = 1/12 V =
83mV, i.e. 4 times as much. Your requirement thus seems quite
demanding! Initial thoughts are that you will probably need at least a
pretty good voltmeter to do this, if not a frequency counter. You
could input 2.75V to CV1, and then try setting CV2 input pot so that
the usual A-100 (nominal) +/-5V range (from LFO/whatever) is
attenuated to +/-10mV, assuming it?s possible to adjust the pot to
give you that (due to the exponential nature of the normal, i.e. not
the ?linear FM?, input the centre frequency won?t be quite at this
value, but with such a narrow, non-standard range, I suspect this is
not of much concern?). I?ll have a quick play tonight, and if I come
up with anything else, I?ll let you know.
Tim
[The views expressed above are entirely those of the writer and do not
represent the views, policy or understanding of any other person or
official body.]
--- In Doepfer_a100@y..., jason kahn <kahn@a...> wrote:
> hello
> hello i have a an a100 system and am trying to work with it in the
> range of only 14000-14200 hz (for a special composition).
> i am using modules like the a-111 vco2, the a-110 vco and the a-145
> lfo, plus different filter modules, etc.
> my question is: does anyone know how i can somehow measure this
> frequency range on the doepfer and only stay in this range?
> thanks in advance for any help.
> best
> jason kahn
