Re:AW: [Doepfer_a100] LFO Divisions
2008-02-12 by Ken Harte
Hi Dieter, Thanks for you reply. I looked up the A-143-4 Multiple Synced VC LFO in the future modules pages and it is what I would like.... almost. When you are designing the module would it be possible to have them share a common external clock source so as I could lock all the LFO rates to either MIDI Clock or to an externally generated squarewave. It would be great if I could have that tight intergration with my MIDI sequencer. I have tried to use the Soft Sync function on the A111. I send a squarewave from my Kenton Pro-Solo into the soft sync on the A111 and then try to get the A111 to generate an LFO that's a multiple of the soft syncs input. It kind of works... Anybody else have any ideas? Hi group... > > Hope this isn't too stupid a question. I like creating basslines with > tight clocked LFO's modulating the filter at different rhythmic > divisions. So 1/4 note, 1/8 note, 16th note and triplets... so as I > can jump between different locked LFO rates and apply them to the > filter as I see fit. Is there a way to create multiple rhythmic > divisions of an LFO. > > cheers > > Ken This will be possible with the planned A-143-4 Multiple Synced VC LFO. But we have no release date so far. The prototype is too slow and we have to make a redesign with a faster microcontroller. Best wishes Dieter Doepfer [Non-text portions of this message have been removed]
