Doepfer
Monster case, standard case, ... opinions wanted
2008-02-22 by José Sogo Flores
The time is come to start thinking about expanding my Doepfer system. Now we
have 4 options: monster case, standard rack case, portable case and low-cost
case. Considering money is not an issue and you are thinking in terms of
having at the end about 4-6 times the number of modules in a standard case,
wich pros and cons do you find for every option? I don't need the Doepfer to
be rackmounted.
Thanks for your opinions in advance.
Best regards
Jose
Re: [Doepfer_a100] Monster case, standard case, ... opinions wanted
2008-02-22 by Floppy
why dont you just buy them all ?
José Sogo Flores schrieb:
> Hi,
> Now we
> low-cost
> case,
> Doepfer to
> be rackmounted.
> Best regards
> Jose
2008-02-22 by Florian Anwander
Hi Jose,
if you want to transport the system to stage or other venues, you
shouldn't take anything else but the portable suitcase. The Monsterrack
is not very comfortable, if you have to transport it on your own.
If you want to use it only in the studio I'd suggest something like the
standard racks in a self built frame or something completely DIY'ed like
those: http://www.doepfer.de/A100_custom.htm
I have two standard racks built in a simple cabinet-like wood rack for
my studio (http://fa.utfs.org/img/rack_A100_blitz.jpg), one Doepfer
portable rack for live, and finally I use a single rack as real portable
system http://fa.utfs.org/diy/a100/index.html (or
http://weltklang-music.de/html/body_langenacht2004.html)
Florian
José Sogo Flores wrote:
> Hi,
> be rackmounted.
> Best regards
> Jose
Florian Anwander                  |ConSol
Tel.   +49(89)45841-133           |Consulting&Solutions Software GmbH
Fax    +49(89)45841-111           |Franziskanerstr. 38, D-81669 München
email: florian.anwander@consol.de |http://www.consol.de
AW: [Doepfer_a100] Monster case, standard case, ... opinions wanted
2008-02-22 by hardware@doepfer.de
That's true for the double monster. But the single monster can be carried by
one person. OK - not for miles, but from the car to the stage it will work.
I did it several times during the last year. In any case a trolley makes
things easier.
Best wishes
Dieter Doepfer
2008-02-22 by Silas Johansen
I would go with G6 cases. First two I would put in a slanted tabletop
rack, next two in another rack, and if I were to get any more after
that I would build, or have somebody build me, two racks with a
slanted front for the lower 12 units and a vertical front for the
upper 6 units, then mount three G6 cases in each. This would be
portable, but more geared towards studio use.
A word on ergonomics: I personally find slanted surfaces nicer to work
with, except when I get above shoulder hight where vertical is nicer.
Ideally, I wouldn't want to go above four or five rows (two G6 and
possibly a G3) in hight, but if I ever extend my synth to a large
enough size it might be necessary - I would probably put stuff that I
didn't need to tweak a lot near the top - say, a standard patch with
two-three VCO's, mixer, VCF, VCA and of course a couple of envelopes
and LFO's - I would probably leave this patched up nearly all the time
and only do minor stuff like changing LFO rates, VCF frequency and
envelope settings.
Another word on ergonomics: You don't want patch cable clutter in
front of modules that you tweak all the time. I work a lot with a
sequencer, and for that reason it is placed on the top row. So is my
manual CV source and an LFO - all easily accessible. Modules along the
rightmost edge are also easy to tweak as jacks are generally to the
left on most modules, another point worth considering. However, don't
forget that short patch cords make less clutter, so putting mixers
between VCO's and filters, VCA's on the other side of the filters and
EG's and LFO's where you need them most often also makes a lot of
sense. Experiment with your layout and don't be afraid to move modules
around.
/Silas
On Fri, Feb 22, 2008 at 2:06 PM, Florian Anwander
<Florian.Anwander@consol.de> wrote:
> Hi Jose,
>  Florian
>  > Hi,
> we
> low-cost
> case,
> to
>  > be rackmounted.
>  > Best regards
>  > Jose
>  > Yahoo! Groups Links
We will show a bottom section for the A-100 suitcase and monster case at
Frankfurt. It will be equipped with one horizontal aligned row of modules
(mainly for controlling modules like joystick, Theremin, wheels, light
controlled voltages and so on) and a second slanted row with 135 degrees to
the horizontal and vertical modules (these are module mounted in the monster
or suitcase). We are waiting for the prototypes from our case manufacturer.
Pictures will follow as soon as they arrive next week.
Best wishes
Dieter Doepfer
2008-02-22 by partlydrone
yup, that might just stop me going DIY. although sheesh, all that
silver and black, don't you have trees in germany?
--- In Doepfer_a100@yahoogroups.com, Guy D2 <guy@...> wrote:
> Yes ! Exactly what I was waiting for.
> I was already designing a similar setup (controls on a slanted surface
> in front of the other modules), but now I can spare myself the trouble,
> sit back, and wait...
> Thanks, Dieter !
> -g
> > case at
> > modules
> > degrees to
> > monster
> > manufacturer.
> > Best wishes
> > Dieter Doepfer
Re: AW: [Doepfer_a100] Monster case, standard case, ... opinions wanted
2008-02-22 by Guy D2
Thanks, Dieter !
-g
> case at
> modules
> degrees to
> monster
> manufacturer.
> Best wishes
> Dieter Doepfer
2008-02-22 by James Husted
I use my portable cases laying on a slanted display shelf I found in
a surplus store. Some of the Guitar amps my company sells have fold
out legs to prop them at an angle to aim up at the performer. A
system like this would also work and be a very cheap add-on to the
existing designs. We also sell some Guitar stands, whose designs
don't rely on holding the guitar by means of the head stock, that
could be modified slightly to hold the portable cases easily (the
lower brackets made to be as deep as the P-cabinets). I had a stand
that held my AKSs whose design was very similar. A inexpensive tripod
like stand would be great and very flexible (and useable by current P-
case owners). Something like this (around $30USD): http://
www.activemusician.com/item--MC.6042  Or this one (Around $15USD):
http://www.wholenote.com/item--MF.454318  Designs like these could
easily hold the P-cases at adjustable angles which is a big bonus to me.
-James
>> work
> case at
> modules
> degrees to
> the monster
> manufacturer.
> Best wishes
> Dieter Doepfer
> similar
Re: Monster case, standard case, ... opinions wanted
2008-02-23 by Stu Grimshaw
>However, don't
interesting :) i find that cables that have to turn round and go back
in front of me get in the way more than long ones that disappear of
the sides/top/bottom and come back again i.e. lots of flat-lying
parallel cables rather than shorter ones that stick out the whole time.
that said, i would add that this is more for live work, where tweaking
is more important than rerouting, and the rack is only two rows high.
but if anyone wants to swap a fistful of short black ones for a
fistful of long red and blue ones, i'm up for it :)
stu
AW: AW: [Doepfer_a100] Monster case, standard case, ... opinions wanted
2008-03-03 by hardware@doepfer.de
> Thanks, Dieter !
The first pics of the monster base frame are now available (from the news
page).
Best wishes
Dieter Doepfer
AW: AW: AW: [Doepfer_a100] Monster case, standard case, ... opinions wanted
> Dieter
> > http://www.doepfer.de/a100_monster_base.htm
> Will this be available as standard case too?
> Florian
Probably yes. So far we have only inquiries/orders for monster base frames.
But we could ask our case manufacturer to built a base frame for the
standard suitcase (i.e. 84 HP) too. The usable width will be probably 76 HP
only as we need about 10 mm (~ HP) one each side for the mechanical
construction.
Dieter
Re: AW: AW: [Doepfer_a100] Monster case, standard case, ... opinions wanted
2008-03-03 by Richard Scott
Yes! I like this idea a lot
and the smaller size is a good idea too
R
  Sent: Monday, March 03, 2008 1:45 PM
  Subject: AW: AW: AW: [Doepfer_a100] Monster case, standard case, ... opinions wanted
  > Dieter
  > Florian
  construction.
  Dieter
I am using the free version of SPAMfighter for private users.
It has removed 367 spam emails to date.
Paying users do not have this message in their emails.
Get the free SPAMfighter here: http://www.spamfighter.com/len
Re: AW: AW: AW: [Doepfer_a100] Monster case, standard case, ... opinions wanted
2008-03-03 by Florian Anwander
Hi Dieter
> construction.
Another possibility: the width might be measured to place two standard
cases on top.
Also another suggestion (for a wide version): install a 3 octave
keyboard plus some space for modules in the flat part.
Florian
2008-03-03 by Guy D2
Very cool, Dieter !
Almost perfect.
Except for one thing: I designed a similar case (well, not really,
only on paper),
where there  was also room for a built-in ribbon controller (and also
possibly
some other tactile surface or controller-thingy)...
As a non-keyboard player, I see such a contraption as a kind of
"control center", where all the joysticks, surfaces, buttons, etc... go.
This is very close, though...
-g
> surface
> trouble,
> > Thanks, Dieter !
> news
> page).
> Best wishes
> Dieter Doepfer
2008-03-03 by mritenburg
Dieter,
This design is outstanding!!!  From a performance perspective, the
ergonomics are spot on.
Now, if we could get a touch controller that will mount in this
frame, we'll be all set!!
Sincerely,
Matthew Ritenburg
surface
trouble,
> > Thanks, Dieter !
the news
> page).
> Best wishes
> Dieter Doepfer
AW: AW: AW: AW: [Doepfer_a100] Monster case, standard case, ... opinions wanted
> Hi Dieter
frames.
HP
construction.
> cases on top.
> Florian
Florian,
there is a mechanical problem. The overall width of the keybeds is about 165
mm (compared to the 128.5 mm of the A-100 front panel height). A case that
is suitable for the installation of a keybed will have to be constructed
completely different: one would need an additional top cover (for the rear
part of the keys), a bottom construction (the keybed has to be lifted up as
they are very flat compared to the depth required for A-100 modules) and an
additional construction for the transition between the keybed and the
modules (e.g. left of the keybed). It's possible but a bit complicated. We
will have to manufacture some custom made metallic and wooden parts to fit
both the keybed and the module section. It would be probably easier to built
a case that has exactly the same length as one of the keybeds (e.g. 3
octaves) as in this case the constructions would be much easier. After all
it's a question of the inquiries as it's impossible for us to have all
versions in stock.
We will have to find e few standard solutions that can be manufactured in
reasonable quantities to keep the costs as low as possible.
As a special design everything can be realized - provided that money is not
an object. Most customers underestimate the costs of special designs as the
working time charges for development and construction have to be payed by
one customer only. A lot of these works has to be done by external companies
(metal work, wood work, paint shop, silk-screen print shop ...) and will we
have to forward the charges from these companies to the customer.
Dieter
Re: AW: AW: AW: AW: [Doepfer_a100] Monster case, standard case, ... opinions wanted
2008-03-03 by Denis Gökdag
Let me add one more suggestion to add to the confusion ;-)
I like the layout of the base frame....but i have no need for it to
be portable. "no need" as in "my a-100 has not left my studio even
once since 1995 and it NEVER will" ;-)
  I'd be quite happy with this box in the a-100 standard frame design
made of aluminium, no lids etc. The size would be fine for me.
Another cool feature would be the option to have the studio version
optionally ship with more than two power supplies, to power a-100
frames from it.
cheers,
d
On 03. Mar 2008, at 6:25 PM, <hardware@doepfer.de>
<hardware@doepfer.de> wrote:
> > Hi Dieter
> base
> frames.
> for the
> probably 76
> HP
> mechanical
> construction.
> standard
> > cases on top.
> > Florian
> Florian,
> about 165
> case that
> constructed
> the rear
> lifted up as
> modules) and an
> complicated. We
> to fit
> to built
> After all
> versions in stock.
> manufactured in
> money is not
> designs as the
> payed by
> companies
> will we
> Dieter
2008-03-03 by partlydrone
that's extremely good, a standard suitcase sized one would definitely
tempt me, although the silver robot stuff in general isn't my thing.
very pleased to see the buff brown of the low cost suitcase, would be
truly great to see this kind of thing in that kind of material, ~80hp
wide, would be class.
and yes, if you're going to build these you really need to sort out
that capacitative touchplate controller for the ultimate faux
buchla/serge feel...
> Very cool, Dieter !
> Almost perfect.
> only on paper),
> possibly
> -g
> > surface
> > trouble,
> > > Thanks, Dieter !
> > news
> > page).
> > Best wishes
> > Dieter Doepfer
2008-03-04 by mritenburg
There is a reason people use this shape often.  It is a very useful
design.
--- In Doepfer_a100@yahoogroups.com, "cray5656" <amnesia@...> wrote:
> HI Dieter and all doepfarians
> This case looks great, it would be cool with an extra 2 rows above ah
> la Buchla shape case
2008-03-04 by Richard Scott
I agree, an extra row or two on top would make it really a monster
and  maybe it looks a little bit too much like a keyboard gone wrong at the moment
Richard
  Sent: Tuesday, March 04, 2008 11:52 AM
  Subject: Re: [Doepfer_a100] Monster case, standard case, ... opinions wanted
It has removed 368 spam emails to date.
2008-03-05 by ErnstKarel
--- In Doepfer_a100@yahoogroups.com, "Richard Scott"
at the moment
That's what's so great about it -- it looks like a demented Fender
Rhodes!  I really like the looks of this thing....
