A HELLO and a A-190/ Clock question!
2008-02-22 by Paul
Hi All! I just recently aquired an A-100 basic in the suitcase and I've been having quite a ball. I understand there is quite a learning curve with these, but I think I'm making pretty good headway. Pretty much just one issue I can't seem to resolve... Last night I decided to hook up the A-100 to my Korg MS-2000R's midi out and give a try with the clock through the A-190 in order to dabble with the A-160 and A-161 without having to use Cubase. I was successful in getting this to go, but the Clock sync was absolutely off, even using the divider. It seems way too fast even at low tempo. I decided to patch in Cubase, same problem, unless I enter notes into the Midi track. Then I can reset the LFO's, ect. just fine. Otherwise, wayyy off. Is this just the nature of the beast? Or do I need to edit my A-190? (GASP! Little buttons!) Thanks for any help in advance! Modular rules! P(Newb!)
