Re: [Doepfer_a100] A-125 phaser (noise issue)
2008-02-23 by Ross Goniakowski
why didn't you just say that to begin with? i'm not trying to make an issue, but my phaser is also noisey as the original poster said...if you would have simply wrote "mine is as well, they all are, this is how i deal with it" i would have never responded to your post, i deal with it as well... but i still would like to know if there is an adjustment to be made that will help with the noise... thanks, rg
----- Original Message ---- From: Bakis Sirros <synth_freak_2000@yahoo.com> To: Doepfer_a100@yahoogroups.com Sent: Saturday, February 23, 2008 4:34:10 PM Subject: Re: [Doepfer_a100] A-125 phaser (noise issue) yes, but noise is common in phasers... --- Ross Goniakowski <carfull@sbcglobal. net> wrote: > sorry...i said i believed you said fix, i accidently > deleted the post before responding.. . > > so now i say it's not a solution, it's a work > around...it doesn't deal with the noise of the phase > shifter, it masks it... > > rg > > > ----- Original Message ---- > From: Bakis Sirros <synth_freak_ 2000@yahoo. com> > To: Doepfer_a100@ yahoogroups. com > Sent: Saturday, February 23, 2008 1:20:32 PM > Subject: Re: [Doepfer_a100] A-125 phaser (noise > issue) > > that's why i said an easy solution, not a fix ;-) > > --- Ross Goniakowski <carfull@sbcglobal. net> wrote: > > > i accidently deleted a reply to this post from > > Bakis, i believe he said an easy fix was to use a > > VCA after the phase shifter... > > > > i don't consider that a fix, i consider that a > > work-around. ..to fix the problem would be to > reduce > > the noise level, not hide it...depending on the > > source material, that may or may not be an > > appropriate solution.... > > > > > > rg > > > > > > ----- Original Message ---- > > From: astroschnautzer <astroschnautzer@ yahoo.com> > > To: Doepfer_a100@ yahoogroups. com > > Sent: Saturday, February 23, 2008 8:46:52 AM > > Subject: [Doepfer_a100] A-125 phaser (noise issue) > > > > I just got this module ,seems to work ok besides > its > > terribly noisy. My soundcards noisefloor > > is at about -90db withoout this plugged in whe i > > plug it in it shows -47db so over 40 db of > > noise... Is this normal for this module or should > I > > send it back? > > > > > > > > > > [Non-text portions of this message have been > > removed] > > > > > > Bakis Sirros - Parallel Worlds / Interconnected / > Memory Geist > [Doepfer_a100] group owner > http://www.parallel -worlds-music. com > http://www.myspace. com/parallelworl dsmusic > http://www.myspace. com/interconnect edmusic > http://www.myspace. com/memorygeist > http://www.DiN. org.uk > http://www.musicama ximamagnetica. com > http://www.shimarec ords.co.uk > http://www.rubber. gr > Athens-Greece > > ____________ _________ _________ _________ _________ > _________ _ > Looking for last minute shopping deals? > Find them fast with Yahoo! Search. http://tools. > search.yahoo. com/newsearch/ category. php?category= > shopping > > > > [Non-text portions of this message have been > removed] > > Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Doepfer_a100] group owner http://www.parallel -worlds-music. com http://www.myspace. com/parallelworl dsmusic http://www.myspace. com/interconnect edmusic http://www.myspace. com/memorygeist http://www.DiN. org.uk http://www.musicama ximamagnetica. com http://www.shimarec ords.co.uk http://www.rubber. gr Athens-Greece ____________ _________ _________ _________ _________ _________ _ Never miss a thing. Make Yahoo your home page. http://www.yahoo. com/r/hs [Non-text portions of this message have been removed]
