Re: [Doepfer_a100] A-125 phaser (noise issue)
2008-02-23 by Ross Goniakowski
sorry...i said i believed you said fix, i accidently deleted the post before responding... so now i say it's not a solution, it's a work around...it doesn't deal with the noise of the phase shifter, it masks it... rg
----- Original Message ---- From: Bakis Sirros <synth_freak_2000@yahoo.com> To: Doepfer_a100@yahoogroups.com Sent: Saturday, February 23, 2008 1:20:32 PM Subject: Re: [Doepfer_a100] A-125 phaser (noise issue) that's why i said an easy solution, not a fix ;-) --- Ross Goniakowski <carfull@sbcglobal. net> wrote: > i accidently deleted a reply to this post from > Bakis, i believe he said an easy fix was to use a > VCA after the phase shifter... > > i don't consider that a fix, i consider that a > work-around. ..to fix the problem would be to reduce > the noise level, not hide it...depending on the > source material, that may or may not be an > appropriate solution.... > > > rg > > > ----- Original Message ---- > From: astroschnautzer <astroschnautzer@ yahoo.com> > To: Doepfer_a100@ yahoogroups. com > Sent: Saturday, February 23, 2008 8:46:52 AM > Subject: [Doepfer_a100] A-125 phaser (noise issue) > > I just got this module ,seems to work ok besides its > terribly noisy. My soundcards noisefloor > is at about -90db withoout this plugged in whe i > plug it in it shows -47db so over 40 db of > noise... Is this normal for this module or should I > send it back? > > > > > [Non-text portions of this message have been > removed] > > Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Doepfer_a100] group owner http://www.parallel -worlds-music. com http://www.myspace. com/parallelworl dsmusic http://www.myspace. com/interconnect edmusic http://www.myspace. com/memorygeist http://www.DiN. org.uk http://www.musicama ximamagnetica. com http://www.shimarec ords.co.uk http://www.rubber. gr Athens-Greece ____________ _________ _________ _________ _________ _________ _ Looking for last minute shopping deals? Find them fast with Yahoo! Search. http://tools. search.yahoo. com/newsearch/ category. php?category= shopping [Non-text portions of this message have been removed]
