Doepfer
Re: [Doepfer_a100] A-125 phaser (noise issue)
2008-02-23 by Ross Goniakowski
mine is very noisey as well...i just try and send it a hot signal, and i would use a vst or similar if i needed something really clean...that being said, i'd love to know if there is an adjustment to make it less noisey (lots of hiss on the output w/nothing plugged in)
rg
----- Original Message ----
Sent: Saturday, February 23, 2008 8:46:52 AM
Subject: [Doepfer_a100] A-125 phaser (noise issue)
I just got this module ,seems to work ok besides its terribly noisy. My soundcards noisefloor
is at about -90db withoout this plugged in whe i plug it in it shows -47db so over 40 db of
noise... Is this normal for this module or should I send it back?
2008-02-23 by Bakis Sirros
easy solution:
use a vca after it, in the patch you're making.
> plugged in)
> rg
> From: astroschnautzer <astroschnautzer@yahoo.com>
> send it back?
> removed]
[Doepfer_a100] group owner
http://www.myspace.com/interconnectedmusic
http://www.myspace.com/memorygeist
http://www.DiN.org.uk
http://www.musicamaximamagnetica.com
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.  http://tools.search.yahoo.com/newsearch/category.php?category=shopping
