A-148 Dual S&H defect?
2008-02-26 by Paul
Hi all, I read the manual and can't find an answer elsewhere. I've had my A-100 (Basic suitcase) going on 2 weeks now and I'm bit by bit learning each module. it just gets better and better. Last night I decided to try the A-148 Dual Sample&Hold and the bottom one runs smoothly and rolls great through -/+, but the upper will only roll over when I repeatedly hit the keys on my Midi controler and it seems sort of chokey and won't trigger continually from an LFO source. I removed it, and made sure the ribbon cable was secure, re started and same thing, while the patch works perfect on the lower one. I understand these are supposed to be functioning identicaly? Do I need to switch a jumper? Maybe it's defective? (i would like to maybe get a clue before I haul all the way out to Pamona for an exchange!) Thanks in advance and putting up with me! PK
