From Balanced Bantam to Doepfer minijack
2008-03-05 by johnppp2
I'm going to be using my system for predominantly audio processing interfacing with a Digidesign 192 via a bantam balanced patchbay. I need to be able to run a bantam cable to minijack input on the Doepfer, and vice versa. Back into the 192 should be ok as i can patch into the unbalanced inputs but whats the best solution for output into the Doepfer? Is there a module that can handle input and outputs in difference jack/xlr sizes?
