Doepfer
Joystick
Joystick
2008-03-29 by jalmari3
I am going to add a joystick to my system. I guess my options are A-174
and Analogue Systems RS220. Has someone tried them both and can comment
their quality?
A-174 seems to have a circular mask, which prevents simultaneous
max/min X and Y values. This doesn't seem sensible... Also, there are
no mini multiples, like in RS220.
On the other hand, A-174 has offset controls instead of attenuators,
which may be more useful in many situations. It is cheaper too.
Someone here commented, that for better ergonomics jacks and knobs
should be above the joystick rather than below it. I guess both A-174
and RS220 can be installed upside down, if desired.
Jari Jokinen
Re: Joystick
2008-03-29 by partlydrone
i have the doepfer one. i find it incredibly useful, well built, and
also often use the offsets as static voltage sources eg to control
wavetables on my a112. the circular cuff is a theoretical problem but
ive not noticed it being an issue. i've vascillated over whether to
remove the spring, but actually its sufficiently cheap that you could
have one sprung, one not, for the same price as the AS version. its
surprising how much accurate pitch control you can have over a sound
source, eg oscillator, esp if using a vca to temper the movements, if
a quantiser wasnt so disproportionately expensive (to the pleasure,
rather than the cost of construction) then i'd be tempted to get one
and use it with the joystick. i actually find the joystick more usable
than the ribbon for wiggly pitch control.
> their quality?
> Jari Jokinen
Re: [Doepfer_a100] Joystick
2008-03-29 by James Husted
I have two of the AS RS220 joysticks. I think they are great. I have
an older model and a newer one, the main difference being the
orientation. They seem to be making them with the jacks on top now,
the older one has them on the bottom. On their site the last time I
looked they showed images of the older (bottom jacks) orientation in
all the pictures except as part of the French connection keyboard
(which would be the orientation of choice for a keyboard module).  The
top is my preferred position since I use portable cases laying on an
angle or face up on their backs. For these positions the cables are
not under my hands. For the standard vertical orientation most seem to
like the jacks at the bottom (cables not hanging over the stick). I
just have one mounted upside-down and re-wired accrdingly - a simple
thing. I cant speak for the Doepfer unit , but the AS module feels
very smooth without the springs - almost too easy to whip around,
which is not a bad thing to me. I remember the AKS joystick having a
bit more "drag" which helps a little for fine movements.
If you get one don't forget to get/make a manual pushbutton module too
(like the Doepfer A-164-1), I wish they would build it into the
joystick module - I always need one right next to the joystick.
-James
> A-174
> comment
> their quality?
> Jari Jokinen
Re: Joystick
2008-03-30 by matijnboshoven
I have one RS220, its the old version with jacks on the bottom. I got
it cheap secondhand because it was so loose gravity pulled it down. I
solved this by rotating the joystick itself inside the module by 90
degrees. Its functionig perfectly now.
There is a simple suplement circuitry possible for any joystick, to
get 4 more outputs. It involves adding and subtracting the horizontal
(X) and vertical (Y) voltages :
-X-Y=A
+X-Y=B
+X+Y=C
-X+Y=D
This can be done with a very simple circuit. Maybe this could find its
way to the DIY page?
--- In Doepfer_a100@yahoogroups.com, James Husted
> -James
> > A-174
> > comment
> > their quality?
> > Jari Jokinen
> > Yahoo! Groups Links
Re: Joystick
2008-03-30 by jalmari3
Thank you for your comments. I am still skeptical about the round mask
in A-174.
How about this?
"I would like to know, if the RS220 joystick PCB "sticks out" past the
faceplate - to the space belonging to the adjacent module. This is the
case with my RS230 and it might cause problems with modules from other
manufacturers."
Jari Jokinen
Re: Joystick
I use the corners of the RS220 all the time. But I never used a A-174
to compare it with, so don't know if the round faceplate in a
disadvantage.
The PCB on the RS220 does not stick out.
> in A-174.
> How about this?
> manufacturers."
> Jari Jokinen
Re: Joystick
Cwejman is also planning a module with joystick:
http://www.cwejman.net/cwejman.net/qvc-4.htm
Re: [Doepfer_a100] Re: Joystick
2008-03-30 by Florian Anwander
Hi
> disadvantage.
I had joysticks from an old video game with rectangular mask and I own
a A-174: To my opinion the circular mask is a big disadvantage.
Florian
