Doepfer
188 bbd extra's
188 bbd extra's
2008-04-20 by floris vanhoof
since this week i have an a-188-1 4096 stages bbd module, (experimented w/ it and read
the manual + questions over here)
and here's a clock question:
the manual states:
 "If the BBD circuit is changed the
max. frequency has to be re-adjusted with a trimming
potentiometer on the pc board of the module (frequency
offset)"
can i speed up the clock to get longer delays with less clock noise? (VCO scale adjustment)
for the blacet time machine i've read:
"they clock the chip with up to 200 khz frequency" (is this overclocking?)
is it a good idea to play around w/ the offset trimpotmeter?
+is there a scheme for /or is anybody doing extra mn3005 chips and/or a build in filter in
this module?
+some of my modules are in a cigar box as live setup, but now with the bbd this doens't
fit anymore, is there anything (cigars, wine,...) that uses 26cm to +-16 cm  boxes?
thanks for the help!! floris
AW: [Doepfer_a100] 188 bbd extra's
2008-04-21 by hardware@doepfer.de
> the manual states:
> offset)"
> and/or a build in filter in this module?
this doens't
cm boxes?
You can overclock the BBDs without any risk to damage the circuits. They
simply stop working if the clock becomes too high. If the clock frequency is
reduced they go back to normal work again.
But if you increase the clock the delay time becomes shorter not longer !
You may use each filter of the A-100 to suppress the clock. We are working
on a dual filter (switched capacitor filter) that is planned especially for
this application.
Best wishes
Dieter Doepfer
