Re: [Doepfer_a100] Serge compatability ?
2008-05-13 by implode7@comcast.net
Actually, that's very good to know, since I'm building a modcan/cynthia/serge system. I very much like the metalbox stuff.
-------------- Original message ---------------------- From: Bakis Sirros <synth_freak_2000@yahoo.com> > yes, Metalbox does banana version modules, if you > want. > i have some banana metalbox modules... > > > --- implode7@comcast.net wrote: > > > > > > > Metalbox is frac rac, isn't it - mini jacks, not > > bananas...unless he does those also. > > -------------- Original message > > ---------------------- > > From: Guy D2 <guy@guyd2.com> > > > > > > > Has anyone any experience with or ideas about > > the wisdom of > > > > interfacing Doepfer modules with as Serge system > > ? > > > > > > > > 1. It seems that Doepfer audio modules run at 5 > > volts peak to peak > > > > (-2.5v to +2.5v ?) - like the Serge - and uses > > bananna plugs too, so > > > > great, right? > > > > > > > > > > Doepfer uses 3mm (mini) phonejacks, not banana's. > > > > > > > 2. How about Panel Size? > > > > > > > Doepfer : 3U > > > Serge: 4U > > > > > > Not really compatible, hardware-wise. Two > > different beasts... > > > > > > > 3. Power supply? > > > > > > > Doepfer does both 115/230V AC > > > Doepfer DC rail: +/- 12V (opt: + 5V) > > > > > > > 4. Any other problems anyone can forsee? > > > > > > > Don't know the electrical specs of the Serge > > systems, > > > but I'd look seriously into the gate/trigger > > voltages > > > before hooking both up. > > > Most current modulars are electrically compatible > > > (their CV/audio signals, and gates mostly too), > > > but not always 100%. > > > > > > Often not a real problem, but be careful in some > > instances. > > > > > > > > > > Finally, are ther other modular systems anyone > > is aware of that would > > > > seem to be compaable with Serge? > > > > > > > > > > MetalBox, Cynthia and ModCan A series all use > > banana jacks, > > > and are more or less compatible with Serge. Buchla > > too... > > > > > > I guess our list moderator (Bakis) can tell you > > all about this, > > > since he owns all of the modules of all of the > > systems... ;-) > > > > > > > > > Personally, when thinking about crossbreeding > > Doepfer with > > > othe modulars, Serge is not the first system > > coming to my mind... > > > > > > > > > On a sidenote: > > > I've been working on a complete list/database of > > current > > > modular systems compatibilities (both mechanical > > and electrical), > > > but didn't finish it yet... Maybe one day... Need > > some help here too. > > > > > > > > > > > > -Guy > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been > > removed] > > > > > > > Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist > [Doepfer_a100] group owner > www. parallel - worlds - music. com > www. myspace. com/ parallelworldsmusic > www. myspace. com/ interconnectedmusic > www. myspace. com/ memorygeist > www. DiN. org. uk > www. musicamaximamagnetica. com > www. shimarecords. co. uk > www. rubberrecords. gr > Athens - Greece > > > [Non-text portions of this message have been removed]
