Doepfer
blew up headphones? + lfo 1 vs 2
2008-05-14 by floris vanhoof
is it possible that i broke my sennheiser hd280 (64 ohm) headphones by listening to doepfer
or formant modulars? the left speaker stopped working, and i only used it w/ my m-box and  directly into doepfer/formant modules.
can i speed up a146 lfo2? i think it's a little slower than a145 lfo 1, it sounds a bit lower in
the "high" position too.
thanks, floris
AW: [Doepfer_a100] blew up headphones? + lfo 1 vs 2
2008-05-15 by hardware@doepfer.de
> thanks, floris
You will have to replace the timing capacitors by other values. I can add
the components overlay of the A-146 with the corresponding capacitors to the
DIY page if you are interested.
Best wishes
Dieter Doepfer
Re: blew up headphones? + lfo 1 vs 2
2008-05-19 by floris vanhoof
hiii, that would be great, thanks!
nobody had problems w/ headphones and modulars?
> > thanks, floris
> Best wishes
> Dieter Doepfer
AW: [Doepfer_a100] Re: blew up headphones? + lfo 1 vs 2
2008-05-20 by hardware@doepfer.de
We have added the timing capacitor positions of these modules:
A-140
A-141
A-142
A-145
A-146
A-147
www(dot)doepfer(dot)com > PRODUCTS > A-100 > DIY page > Timing capacitors
Best wishes
Dieter Doepfer
RE: [Doepfer_a100] Re: blew up headphones? + lfo 1 vs 2
2008-05-20 by David Salter
That's great Dieter,
How do different capacitor value affect the range in time, i.e. if I
replaced 100nF with 1000nF or 10nF what sort of difference would I
notice?
I was thinking that if it's a large difference to make a little pcb and
have an additional switch to change from standard to new value.
Thanks
David
David Salter
Senior Consultant
Thomson Reuters
O +44 (0)20 7542 2402X 52402
M 07990562402
david.salter@thomsonreuters.com
thomsonreuters.com <http://thomsonreuters.com/>
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
On Behalf Of hardware@doepfer.de
Sent: 20 May 2008 11:47
Subject: AW: [Doepfer_a100] Re: blew up headphones? + lfo 1 vs 2
A-140
A-141
A-142
A-145
A-146
A-147
capacitors
Best wishes
Dieter Doepfer
This email was sent to you by Thomson Reuters, the global news and information company.
Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Thomson Reuters.
> notice?
100nF -> 1000nF = tenfold the time or period
100nF -> 10nF = tenth part of the time or period
> Thanks
> David
The capacitor value is proportional to the time or period (e.g. doubling the
capacitor value even doubles the time or period, when the capacitor value is
increased tenfold even the time or period increases tenfold).
Best wishes
Dieter Doepfer
Thank you Dieter
Rgds
david
David Salter
Senior Consultant
Thomson Reuters
M 07990562402
Sent: 20 May 2008 13:58
> notice?
and
> Thanks
> David
value is
Best wishes
Dieter Doepfer
