Doepfer
Re: short patch cables
2008-06-01 by floris vanhoof
i had the same question weeks ago, and asked every (internet/ebay,...) seller i could find,
and nobody had it.
you might find 20 cm.
but i think 10 cm and a lot of different colors (so you could see what you do & touch the
knobs) would be great!
let me know if you find anything.
--- In Doepfer_a100@yahoogroups.com, "Monroe Eskew" <monroe.eskew@...> wrote:
> Does anyone know if/where one can buy extremely short patch cables, say
> around 10-20 cm?
> Monroe
short patch cables
2008-06-01 by Monroe Eskew
around 10-20 cm?
Monroe
RE: [Doepfer_a100] Re: short patch cables
2008-06-02 by David Salter
Try SMS http://syntheticmusicsystems.co.uk/
Although not listed on the site, Andy provides short patch cables with a
MARS/Planet 7 setup to interconnect the two.
David
David Salter
Senior Consultant
Thomson Reuters
O +44 (0)20 7542 2402X 52402
M 07990562402
david.salter@thomsonreuters.com
thomsonreuters.com <http://thomsonreuters.com/>
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
On Behalf Of floris vanhoof
Sent: 01 June 2008 21:13
Subject: [Doepfer_a100] Re: short patch cables
and nobody had it.
you do & touch the
<mailto:Doepfer_a100%40yahoogroups.com> , "Monroe Eskew"
say
> around 10-20 cm?
> Monroe
Re: [Doepfer_a100] Re: short patch cables
2008-06-02 by Monroe Eskew
Thanks for the link.
I would still have an interest in even shorter cables.  The purpose is to
patch a bunch of adjacent modules while minimizing the wire mess.  I was
thinking about making some myself.  I could order in bulk and sell them to
others for not much... probably $2 US each.  What kind of demand would there
be for this-- can I get a show of hands to see if its worth it?  And would
people like 10 cm, 15 cm, what?
Monroe
On Mon, Jun 2, 2008 at 1:44 AM, David Salter <
> David
> David Salter
> Senior Consultant
> Thomson Reuters
> M 07990562402
> david.salter@thomsonreuters.com <david.salter%40thomsonreuters.com>
> From: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>[mailto:
> Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>]
> To: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>
> and nobody had it.
> you do & touch the
> --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>
> <mailto:Doepfer_a100%40yahoogroups.com <Doepfer_a100%2540yahoogroups.com>>
> , "Monroe Eskew"
> say
> > around 10-20 cm?
> > Monroe
2008-06-04 by hemi_ch
yeah, short patchcables are very important.
I have them from 8cm up to 15cm in 2cm increments ( more less ) .
even 15cm is much too long many times.
( I think measurement was between the plugs)
I would take a bunch too if somebody gets them Manufactured.
( no handspoldering )
H.C.
is to
them to
would there
would
> Cheers,
> Monroe
with a
> > David
> > David Salter
> > Senior Consultant
> > Thomson Reuters
> > M 07990562402
> > david.salter@... <david.salter%40thomsonreuters.com>
> > and nobody had it.
> > you do & touch the
> > , "Monroe Eskew"
> > say
> > > around 10-20 cm?
> > > Monroe
Yes, a Poll would be perfect ! thanks.
that you cannot make every lenght is absolutely clear.
20cm tip to tip is a very good lenght if you just like to make one
more lenght
Dieter, please make shure that we all speak from tip to Tip lenght
when making the Poll
H.c.
> > H.C.
> We could ask our cable manufacturer to produce a shorter cable with
the next
> run. How about a poll which length most users would prefer (e.g. 10
or 15 or
> 20cm) ? We will not offer all kind of lenghts but one more cable type
> shorter than 30 cm would be conceivable.
> Best wishes
> Dieter Doepfer
AW: [Doepfer_a100] Re: short patch cables
2008-06-04 by hardware@doepfer.de
> H.C.
We could ask our cable manufacturer to produce a shorter cable with the next
run. How about a poll which length most users would prefer (e.g. 10 or 15 or
Best wishes
Dieter Doepfer
2008-06-04 by Silas Johansen
If two standard 8 HP wide modules each with 5 sockets and 5 pots are
mounted next to each other a 18.5cm tip-to-tip cable will allow you to
connect any socket on one to any socket on the other. I think an extra
1½cm slack wouldn't hurt, so 20cm tip-to-tip sounds to me like a good
choice for a shorter length patch cable.
>> H.C.
> Best wishes
> Dieter Doepfer
2008-06-04 by Monroe Eskew
My vote is for 15cm
> > H.C.
> next
> or
> Best wishes
> Dieter Doepfer
Re: AW: [Doepfer_a100] Re: short patch cables (new Poll!)
2008-06-05 by Bakis Sirros
ok, a new poll has been created for the cable length
of a new short patchcord.
please vote soon, as this poll will remain open for
only 2 weeks.
thanks,
Bakis.
> ( more less ) .
> Manufactured.
> > H.C.
> one more cable type
> Best wishes
> Dieter Doepfer
2008-06-06 by Silas Johansen
Bakis,
Would you please specify whether we're voting on the length tip-to-tip
or the cable length between plugs?
Also, as the plugs on my Doepfer patch cables are about 4.5cm long a
10cm tip-to-tip cable would only have an "effective length" of about
1cm and thus could not be used to connect two 8HP modules next to each
other...
On Thu, Jun 5, 2008 at 2:30 AM, Bakis Sirros <synth_freak_2000@yahoo.com> wrote:
> only 2 weeks.
> thanks,
> Bakis.
>> ( more less ) .
>> Manufactured.
>> > H.C.
>> one more cable type
>> Best wishes
>> Dieter Doepfer
2008-06-06 by Bakis Sirros
hello,
its cable length between plugs then.
the cable lengths were suggested by another email (from Dieter).
these are not my choises, so i cannot be really sure.
but, in order for Dieter to suggest 10cm, i assume its cable length between plugs...
but, i just measured one of the doepfer black cords and its 30cm tip to tip! (OF COURSE).
that means that the doepfer black (30cm) cables are already 23cm in cable length between plugs...
so, the third choise of the poll (20cm) does not differ a lot from the black cables we already have...
anyway, Dieter will give details for this, as soon as he comes back, as he is not at the office until 15th of June.
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
--- On Fri, 6/6/08, Silas Johansen <sijodk@gmail.com> wrote:
Subject: Re: AW: [Doepfer_a100] Re: short patch cables (new Poll!)
Date: Friday, June 6, 2008, 5:35 PM
Bakis,
other...
On Thu, Jun 5, 2008 at 2:30 AM, Bakis Sirros <synth_freak_ 2000@yahoo. com> wrote:
> only 2 weeks.
> thanks,
> Bakis.
>> ( more less ) .
>> Manufactured.
>> > H.C.
>> one more cable type
>> Best wishes
>> Dieter Doepfer
2008-06-07 by E_K_
The "30 cm" Doepfer cable I just pulled out to measure is almost 34 cm tip-to-tip, and
just under 27 cm if you measure just the actual cable, excluding the thicker 'grip' part
(sorry I don't know the terminology).   From the base of each metal plug, the length is 31
cm.  Likewise the "50 cm" cable I measured is, measuring the whole length except the
actual metal plugs, 51 cm.
Based on this way of measuring, I think "18 cm" or "18.5 cm" would be an ideal length for
a short cable, perfect for patching up two utility modules that are right next to each other,
which I'm sure many of us are doing quite often.
But if I had to choose between 15 cm and 20 cm I'd choose 15 (which is what I voted
for)....
--- In Doepfer_a100@yahoogroups.com, "Silas Johansen" <sijodk@...> wrote:
> Bakis,
> other...
