Understanding the signal path
2008-07-11 by techmaster242
I'm trying to make sense of how everything generally wires together in a modular. Obviously, anything is possible, and the experimentation is where the fun comes in, but I would like to understand the "typical" way that a synth is wired, so that I can know what I'm doing when I deviate from it. I'm just not 100% sure of how the signal flows from one device to another to form a complete synth. I've pieced together bits and pieces, and just wanted to put it all down in front of you guys, and see if I'm on the right track. So, here goes. basic synth: midi gets converted to cv by a-190 cv goes into VCO, which puts out audio signal audio signal from VCO goes into VCA, which puts out audio signal audio signal from VCA goes into your mixer, recorder, or DAW a bit fancier: gate signal from a-190 goes into VC splitter one VC goes into ADSR then VCA to control volume envelope another VC goes into VCO sync so wave starts cleanly on every midi note for a moog type of sound: cv from a-190 goes into a cv splitter cv's go into same setup as above, but into 2 or 3 chains of VCO->ADSR/VCA, slightly detuned from one another, mixing wave shapes, etc to fatten up sound... all VCA's audio outputs go into an audio mixer, which mixes down to one signal going into your DAW. LFO's can then basically be plugged into any VC input in any above setup to provide modulation, or introduce some variance to your sound. Am I thinking about this in the right way? Obviously, you can run VCO's or LFO's into each other's sync inputs and get some chopped up waves with weird harmonics and stuff, but I'm just trying to understand the absolute basics of how this works before I really start tearing up the sound and see what this beast is truly capable of. :)
