Doepfer
WG: [Doepfer_a100] discontinuation of all modules with CEM3320, CEM3340 and CEM3381/PA381
2008-08-04 by hardware@doepfer.de
> Hmm... considering that module was mentioned;
> How far away if the A-111-2 Dynamic VCO prototype from release?
There are still some additions/changes to be made. For me the most important
thing is the missing rotary octave switch. In the prototype we have a wide
range tuning knob and a fine tune knob available. From my point of view it's
too complicated to use the tuning knob to adjust the frequency to another
octave. Maybe I'm a bit spoiled by the A-110 and A-111-1 in this regard but
for me it's a must have. Unfortunately this addition affects all pc boards
of the module and the front panel layout and requires a total redesign.
Best wishes
Dieter Doepfer
[Doepfer_a100] wide range tuning of VCO continous vs switched, was: discontinuation of all modules with CEM3320, CEM3340 and CEM3381/PA381
2008-08-04 by Florian Anwander
Hi Dieter
I bought the Roland System 100 from Bakis some month ago, which has a
VCO without octave switch, but a wide range potentiometer and a fine
tune. I really appreciate this feature for a lot of sounds and find it
extremely more useful than a 5- or 6-octave switch. Nevertheless I
sometimes miss the possibility to switch one ocate up or down. So my
suggestion is:
- wide range pot 10 octaves
- fine tune 10 semitones
- on-off-on toggle switch with one octave up, normal, one octave down.
Florian
> Best wishes
> Dieter Doepfer
Re: wide range tuning of VCO continous vs switched, was: discontinuation of all
2008-08-05 by selfoscillate
while florians idea is good, i still like the
rotary octave switch better.
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, Florian Anwander
<Florian.Anwander@...> wrote:
> Hi Dieter
> suggestion is:
> Florian
important
have a wide
view it's
another
regard but
pc boards
redesign.
> > Best wishes
> > Dieter Doepfer
AW: [Doepfer_a100] Re: wide range tuning of VCO continous vs switched, was: discontinuation of all
2008-08-05 by hardware@doepfer.de
> best wishes
> ingo
I think a good compromise would be a jumper for the tune potentiometer that
defines the tuning range: ~ +/- 1/2 octave (for customers who prefer the
octave switches) or ~ +/-5 octaves or even more (for customers who prefer a
wide range for the tune control).
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] Re: wide range tuning of VCO continous vs switched, was: discontinuation of all
2008-08-05 by Florian Anwander
Hi Dieter
That is ok, but where to place the rotary switch for multiple octave
switching on the frontpanel?
Florian
AW: AW: [Doepfer_a100] Re: wide range tuning of VCO continous vs switched, was: discontinuation of all
that
prefer a
That's indeed our main problem ...
Dieter
2008-08-05 by achtung_999
I have been giving it a thought the widerange tuning might be very cool. But
the rotaryswitch has a lot of uses too.Why then use a jumper? A switch on
the front would be even nicer then.
just my thought...
On Tue, Aug 5, 2008 at 1:03 PM, Florian Anwander <Florian.Anwander@consol.de
> wrote:
>   Hi Dieter
> that
> a
> Florian
Re: AW: AW: [Doepfer_a100] Re: wide range tuning of VCO continous vs switched, was: discontinuation of all
Hi Dieter
This is why I suggested the on/off/on switch, which usually can be
placed between two potentiometers.
The other options is to go more modular: offer only some basic CV in-s
at the core module and offer additionally an extended CV mixer, with
multiple octave switching, coarse, fine, micro tune, and several
modulation inputs with mod-amount potentiometers for log an lin modulation.
(I dont want to be nasty, but I suggested this module quite often - may
be I should do a small business for modules with underrated sales
chances ;-)))) )
Florian
AW: AW: AW: [Doepfer_a100] Re: wide range tuning of VCO continous vs switched, was: discontinuation of all
> Hi Dieter
> modulation.
> chances ;-)))) )
> Florian
Florian,
I would not recommend that :-)
E.g. the mix expander module A-138x is the poorest selling module ever ! The
module is available since early 2007 and we sold less than 25 so far (less
than 2 per month).
Dieter
2008-08-05 by James Husted
Why not a combo of both - a multi-octave select switch wit it's last
position turning the tuning knob into a wide range tuning knob.  The
best of both worlds.
-James
>> best wishes
>> ingo
> potentiometer that
> prefer the
> prefer a
> Best wishes
> Dieter Doepfer
2008-08-06 by herwig.krass
it would be better to use a combination of a simple module of octave knob and precision
adder.
ciao herw
--- In Doepfer_a100@yahoogroups.com, James Husted <the_ersatz_planet@...> wrote:
> -James
> >> best wishes
> >> ingo
> > potentiometer that
> > prefer the
> > prefer a
> > Best wishes
> > Dieter Doepfer
> > Yahoo! Groups Links
Re: [Doepfer_a100] Re: wide range tuning of VCO continous vs switched, was: disconti
2008-08-06 by James Husted
Actually that would be a better idea. Then the cost of the main VCO
could be cheaper to those who don't need these options. This module
of course would work for VCFs also. For me the module would be
perfect if it had an Octave select switch, a fine tune knob, a CV in
(or two that sum) and multiple outs (4 would be nice). It would be
used as a master VCO controller module (didn't Moogs have a master
VCO module of some type?). One or two CV in be summed and could
control any combination of 4 VCO/VCFs without loading and have a
master transpose too. It would work great controlling multiple band-
pass filters too. Basically it would be a A-185-2 with a octave
select replacing the toggles and the attenuator becoming a voltage
source. The A-185-2 is almost perfect.
-James
> adder.
> ciao herw
2008-08-06 by jalmari3
I just purchased my first oscillator without a wide range continuous
tuning knob. (It has an octace switch and a fine tune of +/-6
semitones). I find this arrangement frustrating and unsuitable for my
needs. In my opinion Plan B M15 has it right: Continuous Coarse tuning
and Fine tuning. And importantly the fine tuning is only +/-1 semitone,
which makes tuning actually precise and easy.
Of course, if there is an *additional* octave switch, I don't mind,
except that it takes some space. I would still propably rather use
something like 185-2.
