red band orientation
2008-08-05 by Monroe Eskew
Is the red band on the power ribbon just a marker to help us? Is the power ribbon functionally symmetrical, so that we can reverse the plug orientation on both ends and be alright? Thanks, Monroe
2008-08-05 by Anthony Rolando
Nooooooo (sound of man falling off a cliff). http://www.doepfer.de/a100_man/a100t_e.htm Please read this page. Tony > To: Doepfer_a100@yahoogroups.com > From: monroe.eskew@gmail.com > Date: Tue, 5 Aug 2008 10:16:34 -0500 > Subject: [Doepfer_a100] red band orientation > > Is the red band on the power ribbon just a marker to help us? Is the > power ribbon functionally symmetrical, so that we can reverse the plug > orientation on both ends and be alright? > > Thanks, > Monroe > > ------------------------------------ > > Yahoo! Groups Links > > > _________________________________________________________________ Get more from your digital life. Find out how. http://www.windowslive.com/default.html?ocid=TXT_TAGLM_WL_Home2_082008 [Non-text portions of this message have been removed]
2008-08-05 by stuadh
In case you're in any doubt, I have a handful of spare Doepfer cable that you can have for nothing. just drop me a PM with your details. Yours Aye Stuadh --- In Doepfer_a100@yahoogroups.com, James Husted <the_ersatz_planet@...> wrote:
> > Technically speaking you can reverse the plug orientation ONLY if you > do on both ends and ONLY if you make sure on the 10-pin plugs that > the socket (the cable end) us lined up to the -12V pins and doesn't > over hang that end of the header at all. The cables are just cables - > no electronics involved. The cables use 2 wires for each voltage/gnd > connection. the 2 columns of the headers are the same for each row > (-12v, GND, +12v, +5v etc.) so should work even if only one column is > plugged in though that cuts down the current handling ability of the > cable. As you may notice the page referenced below does not mention > the red stripe at all but it does stress "Pay attention that applying > other than the described voltages or changing the polarity will > result in the module's instant destruction !" This will for sure > happen if the cable ends are nor oriented the same at both ends. > Doepfer has made this easy be printing the voltages next to the pins > on all the modules I remember. In practice you should make sure all > modules in your system have the same cable orientation and it it > would be a good idea to match the orientation of factory delivered > modules that have the cable attached already - just so you don't mess > up when you re-arrange them in the future (and you WILL re-arrange > them in the future!). A good arrangement would be to have the red > stripe always at the -12v pins that way the cable will be easy to use > on both 10 and 16 pin headers. > > -James > > > On Aug 5, 2008, at 8:43 AM, Anthony Rolando wrote: > > > > > Nooooooo (sound of man falling off a cliff). > > > > http://www.doepfer.de/a100_man/a100t_e.htm > > > > Please read this page. > > > > Tony > > > >> To: Doepfer_a100@yahoogroups.com > >> From: monroe.eskew@... > >> Date: Tue, 5 Aug 2008 10:16:34 -0500 > >> Subject: [Doepfer_a100] red band orientation > >> > >> Is the red band on the power ribbon just a marker to help us? Is the > >> power ribbon functionally symmetrical, so that we can reverse the > >> plug > >> orientation on both ends and be alright? > >> > >> Thanks, > >> Monroe > >> > >> ------------------------------------ > >> > >> Yahoo! Groups Links > >> > >> > >> > > > > _________________________________________________________________ > > Get more from your digital life. Find out how. > > http://www.windowslive.com/default.html?ocid=TXT_TAGLM_WL_Home2_082008 > > > > [Non-text portions of this message have been removed] > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > >
I can't see evidence that there is something peculiar about where the red band is painted. One has to get the right voltages to the right places, but can't one accomplish this by reversing the orientation of the plugs at BOTH ends simultaneously? (The reason I ask is that I was sold a ribbon with the red band printed on the wrong side, and I have an ASys case which only allows one orientation going into the power board.) On Aug 5, 2008, at 10:43 AM, Anthony Rolando wrote: > > Nooooooo (sound of man falling off a cliff). > > http://www.doepfer.de/a100_man/a100t_e.htm > > Please read this page. > > Tony > > > To: Doepfer_a100@yahoogroups.com > > From: monroe.eskew@gmail.com > > Date: Tue, 5 Aug 2008 10:16:34 -0500 > > Subject: [Doepfer_a100] red band orientation > > > > Is the red band on the power ribbon just a marker to help us? Is the > > power ribbon functionally symmetrical, so that we can reverse the > plug > > orientation on both ends and be alright? > > > > Thanks, > > Monroe > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > > __________________________________________________________ > Get more from your digital life. Find out how. > http://www.windowslive.com/default.html?ocid=TXT_TAGLM_WL_Home2_082008 > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed]
2008-08-05 by James Husted
Technically speaking you can reverse the plug orientation ONLY if you do on both ends and ONLY if you make sure on the 10-pin plugs that the socket (the cable end) us lined up to the -12V pins and doesn't over hang that end of the header at all. The cables are just cables - no electronics involved. The cables use 2 wires for each voltage/gnd connection. the 2 columns of the headers are the same for each row (-12v, GND, +12v, +5v etc.) so should work even if only one column is plugged in though that cuts down the current handling ability of the cable. As you may notice the page referenced below does not mention the red stripe at all but it does stress "Pay attention that applying other than the described voltages or changing the polarity will result in the module’s instant destruction !" This will for sure happen if the cable ends are nor oriented the same at both ends. Doepfer has made this easy be printing the voltages next to the pins on all the modules I remember. In practice you should make sure all modules in your system have the same cable orientation and it it would be a good idea to match the orientation of factory delivered modules that have the cable attached already - just so you don't mess up when you re-arrange them in the future (and you WILL re-arrange them in the future!). A good arrangement would be to have the red stripe always at the -12v pins that way the cable will be easy to use on both 10 and 16 pin headers. -James
On Aug 5, 2008, at 8:43 AM, Anthony Rolando wrote: > > Nooooooo (sound of man falling off a cliff). > > http://www.doepfer.de/a100_man/a100t_e.htm > > Please read this page. > > Tony > >> To: Doepfer_a100@yahoogroups.com >> From: monroe.eskew@gmail.com >> Date: Tue, 5 Aug 2008 10:16:34 -0500 >> Subject: [Doepfer_a100] red band orientation >> >> Is the red band on the power ribbon just a marker to help us? Is the >> power ribbon functionally symmetrical, so that we can reverse the >> plug >> orientation on both ends and be alright? >> >> Thanks, >> Monroe >> >> ------------------------------------ >> >> Yahoo! Groups Links >> >> >> > > _________________________________________________________________ > Get more from your digital life. Find out how. > http://www.windowslive.com/default.html?ocid=TXT_TAGLM_WL_Home2_082008 > > [Non-text portions of this message have been removed] > > > ------------------------------------ > > Yahoo! Groups Links > > >
Ok, I should have read your original question more closely. The minute I hear something about reversing power cables I get nervous... Tony > To: Doepfer_a100@yahoogroups.com > From: monroe.eskew@gmail.com > Date: Tue, 5 Aug 2008 11:15:11 -0500 > Subject: Re: [Doepfer_a100] red band orientation > > I can't see evidence that there is something peculiar about where the > red band is painted. One has to get the right voltages to the right > places, but can't one accomplish this by reversing the orientation of > the plugs at BOTH ends simultaneously? (The reason I ask is that I > was sold a ribbon with the red band printed on the wrong side, and I > have an ASys case which only allows one orientation going into the > power board.) > > > On Aug 5, 2008, at 10:43 AM, Anthony Rolando wrote: > > > > > Nooooooo (sound of man falling off a cliff). > > > > http://www.doepfer.de/a100_man/a100t_e.htm > > > > Please read this page. > > > > Tony > > > > > To: Doepfer_a100@yahoogroups.com > > > From: monroe.eskew@gmail.com > > > Date: Tue, 5 Aug 2008 10:16:34 -0500 > > > Subject: [Doepfer_a100] red band orientation > > > > > > Is the red band on the power ribbon just a marker to help us? Is the > > > power ribbon functionally symmetrical, so that we can reverse the > > plug > > > orientation on both ends and be alright? > > > > > > Thanks, > > > Monroe > > > > > > ------------------------------------ > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > __________________________________________________________ > > Get more from your digital life. Find out how. > > http://www.windowslive.com/default.html?ocid=TXT_TAGLM_WL_Home2_082008 > > > > [Non-text portions of this message have been removed] > > > > > > > > > > [Non-text portions of this message have been removed] > > > ------------------------------------ > > Yahoo! Groups Links > > > _________________________________________________________________ Got Game? Win Prizes in the Windows Live Hotmail Mobile Summer Games Trivia Contest http://www.gowindowslive.com/summergames?ocid=TXT_TAGHM [Non-text portions of this message have been removed]
You are very correct - The AS system power supply headers are more different than just the keyed headers, the pin-out is different also - Big City sells adaptor cables to go from AS modules to Doepfer cases but don't know the abut the other way round. The AS site is pretty poor on the technical details. At least I can't find things like weather a module uses +5V or not on their site any where (other than "+5V used on digital modules). They show their power supply rails as being Rail 1=+12v, Rail 2=+5V and Rail 3= -12V. These are not in the same order as the doepfer -12v, GND, GND, +12V, +5 arrangement of course - hence the adaptor cables. -James
On Aug 5, 2008, at 9:15 AM, Monroe Eskew wrote: > I can't see evidence that there is something peculiar about where the > red band is painted. One has to get the right voltages to the right > places, but can't one accomplish this by reversing the orientation of > the plugs at BOTH ends simultaneously? (The reason I ask is that I > was sold a ribbon with the red band printed on the wrong side, and I > have an ASys case which only allows one orientation going into the > power board.) >
2008-08-05 by Brandon Daniel
On Tue, Aug 5, 2008 at 9:15 AM, Monroe Eskew <monroe.eskew@gmail.com> wrote: > I can't see evidence that there is something peculiar about where the > red band is painted. One has to get the right voltages to the right > places, but can't one accomplish this by reversing the orientation of > the plugs at BOTH ends simultaneously? Yes, though you'll want to double-check continuity to the appropriate places before ever powering up a module on this cable, and it couldn't hurt to mark the cable somehow on the module end so that you don't accidentally forget that you did this at some point in the future and fry something. In short, yeah, you could do this, but it greatly increases the chances that you'll screw something up in the future. -Brandon
2008-08-05 by Laurie Biddulph
The stripe is normally used to identify pin 1 and this is the way it should be used. However, on systems like Doepfer the only important point is that the stripe is orientated to the connector/board the same at both ends i.e. bottom-to-bottom (described way) or top-to-top. Some systems like my Panther, however, use polarised connectors (the headers on my modules are boxed and orientated) and it is essential that pin 1 goes to the right spot and, theoretically, the strip is not important as long as pin 1 is connected to pin 1 and is installed in the right orientation. So, the technically correct way is that the stripe should identify pin 1 on the connector and at both ends. If this is followed by everyone then you will not have problems installing power cables as long as you observe the orientation markings on the modules that do not use a polarised connector. Best Regards (Mr) Laurie Biddulph Phone: +61 (0)2 4340 0938 Mobile: 0400 257 645 Elby Designs ABN: 70 022 727 605 http://www.elby-designs.com This e-mail and any files transmitted with it are confidential and intended for the addressee only. If you are not the addressee you may not copy, forward, disclose or otherwise use it, or any part of it, in any form whatsoever. If you have received this e-mail in error please notify the sender and ensure that all copies of this e-mail and any files transmitted with it are deleted. Any views or opinions represented in this e-mail are solely those of the author and do not necessarily represent those of Elby Designs. Although this e-mail and its attachments have been scanned for the presence of computer viruses, Elby Designs will not be liable for any losses as a result of any viruses being passed on. Please consider the environment before printing this email ----- Original Message -----
From: "Monroe Eskew" <monroe.eskew@gmail.com> To: <Doepfer_a100@yahoogroups.com> Sent: Wednesday, August 06, 2008 1:16 AM Subject: [Doepfer_a100] red band orientation > Is the red band on the power ribbon just a marker to help us? Is the > power ribbon functionally symmetrical, so that we can reverse the plug > orientation on both ends and be alright? > > Thanks, > Monroe > > ------------------------------------ > > Yahoo! Groups Links > > >
2008-08-06 by hardware@doepfer.de
> You are very correct - The AS system power supply headers are more > different than just the keyed headers, the pin-out is different also > - Big City sells adaptor cables to go from AS modules to Doepfer > cases but don't know the abut the other way round. The AS site is > pretty poor on the technical details. At least I can't find things > like weather a module uses +5V or not on their site any where (other > than "+5V used on digital modules). They show their power supply > rails as being Rail 1=+12v, Rail 2=+5V and Rail 3= -12V. These are > not in the same order as the doepfer -12v, GND, GND, +12V, +5 > arrangement of course - hence the adaptor cables. > > -James Analogue Haven has adapter boards available that can be used to connect Bob William's AS modules to the A-100 bus (I know it as we manufacture these adapters as a special design for AH). The AS uses 16-pin IC connectors (like integrated circuits) with this pinout GND GND (side with the IC marker) GND GND +12V +12V +12V +12V +5V +5V +5V +5V -12V -12V -12V -12V So it's totally different from the A-100 bus which uses not only a different type of connectors but has also a different sequence of the pin assignment: GATE GATE CV CV +5V +5V +12V +12V GND GND GND GND GND GND -12V -12V (colored wire of the ribbon cable) Best wishes Dieter Doepfer
