Doepfer
A-190 portamento
A-190 portamento
2008-10-20 by madrayken
Having just constructed my modular, I'm going through all my units,
trying to ensure I understand them as well as possible. One that still
baffles me is the A-109 Midi-CV unit, in particular its Glide
parameter.
I'm using my Andromeda as a midi-keyboard, plugging it into the Midi-
In, and editing the Glide parameter so that it's at 127 (which should
make it glide pretty slowly). However, nothing happens! The keys all
play exactly as normal, no glide at all. I know I'm not accidentally
setting the Config mode parameter because the Glide equivalent is
Offset, and I'd notice if I was accidentally setting that.
Any advice? Am I fundamentally misunderstanding the way the glide
setting works?
Re: A-190 portamento
2008-10-21 by madrayken
Ah. Then the problem's with the Andromeda - the portamento control
does not send midi 65: it's only an internal switch.
Thanks.
--- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote:
> > -----Ursprüngliche Nachricht-----
> > Von: Doepfer_a100@yahoogroups.com
> > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von madrayken
> > Gesendet: Dienstag, 21. Oktober 2008 01:18
> > An: Doepfer_a100@yahoogroups.com
> > Betreff: [Doepfer_a100] A-190 portamento
units,
still
> > parameter.
Midi-
should
all
accidentally
> > setting works?
> Please refer to the pages 15 (manual glide adjustment) and 18 (Midi
control
> of the glide function). You have to transmit midi control change
numbers #65
> for glide on/off and #5 for portamento time. If you still have
questions
> please contact Matthias Marass (keyboards@...). He is responsible
for
> the A-190 service.
> Best wishes
> Dieter Doepfer
AW: [Doepfer_a100] A-190 portamento
2008-10-21 by yahoo@doepfer.de
> parameter.
> setting works?
Please refer to the pages 15 (manual glide adjustment) and 18 (Midi control
of the glide function). You have to transmit midi control change numbers #65
for glide on/off and #5 for portamento time. If you still have questions
please contact Matthias Marass (keyboards@doepfer.de). He is responsible for
the A-190 service.
Best wishes
Dieter Doepfer
