Maybe to explain the idea a bit differently:
We could also think of it like a twisted version of the A167 analog
comparator.
With one big difference that the output is a random value between the low
and high value.
(and of course that it needs to be triggered).
On Sat, Nov 1, 2008 at 8:58 PM, achtung_999 <heinrich.himmelwasser@gmail.com
> wrote:
> Thanks Bakis!
> On Sat, Nov 1, 2008 at 6:29 PM, Bakis Sirros <synth_freak_2000@yahoo.com>wrote:
>> ok, i'll re-make the poll.
>> Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist
>> [Doepfer_a100] group owner
>> www. parallel - worlds - music. com
>> www. myspace. com/ parallelworldsmusic
>> www. myspace. com/ interconnectedmusic
>> www. myspace. com/ memorygeist
>> www. DiN. org. uk
>> www. musicamaximamagnetica. com
>> www. shimarecords. co. uk
>> www. rubberrecords. gr
>> Athens - Greece
>> --- On Sat, 11/1/08, achtung_999 <heinrich.himmelwasser@gmail.com<heinrich.himmelwasser%40gmail.com>>
>> wrote:
>> From: achtung_999 <heinrich.himmelwasser@gmail.com<heinrich.himmelwasser%40gmail.com>
>> Subject: [Doepfer_a100] warming up another old idea
>> To: doepfer_a100@yahoogroups.com <doepfer_a100%40yahoogroups.com>
>> Date: Saturday, November 1, 2008, 4:43 PM
>> Hello,
>> In my list of wishes I have one old wish that is still there, that was
>> already a poll once:
>> http://launch. groups.yahoo. com/group/ Doepfer_a100/ surveys?id=
>> 12050590
>> "the Tendency mask generator at Sonology is a device which you feed an
>> upper
>> limit and a lower limit as cv inputs [in a doepfer system it could be an
>> extension of the a172 max/min]. There's also a clock which can either be
>> internal or an external pulse. The device gives out random values between
>> the upper and lower limits at the clock rate."
>> I would think as a Doepfer module it could be sort of a 'pimped S&H'.
>> One input for the upper limit CV, one input for the lower limit CV, and a
>> clock input.
>> Output give a random value between the upper and lower limit CV at the
>> time
>> of the clock trigger.
>> I guess that this is all possible with a combination of several S&H
>> modules
>> and A172's. (I unfortunately only have one)
>> But wouldn't it be nice to have as a standalone unit? I guess it would fit
>> in a 4HP unit.
>> Another extra option that would be nice, would be an internal clock that
>> could go at extremely high rates.
>> But this would of course make the module bigger in size and more
>> expensive.
>> Thanks for your attention,
>> Ernst
>> [Non-text portions of this message have been removed]
