A-152 Modification: Trigger out on address selection
2008-12-18 by Doug
2008-12-18 by Doug
Hi folks using the A-152 with a cv input immediately gives rise to the need for a trigger on address selection. I'm thinking a socket for this could fit at the bottom of the dig outs section. Has anyone done this? Another thought is a difference or differentiator module that could generate triggers on discontinuities. Something like this could be built from an analog shift register and a comparator, I suppose! Thanks, Doug
2008-12-18 by yahoo@doepfer.de
> Hi folks using the A-152 with a cv input immediately gives rise to the > need for a trigger on address selection. I'm thinking a socket for > this could fit at the bottom of the dig outs section. Has anyone done > this? > > Another thought is a difference or differentiator module that could > generate triggers on discontinuities. Something like this could be > built from an analog shift register and a comparator, I suppose! > > Thanks, > Doug Not necessary :-) Module A-152 has a non-published feature (valid for all A-152 manufactured later than October 2004): RC4 of the PIC16F676 outputs a short 5V trigger signal whenever the address changes. RC4 is pin 6 of the PIC16F676 and is also available on pin 2 of the expansion connector JP6 (next to the bus connector on the A-152 main board / board A). Attention: the signal is not buffered/protected. You should at least add a protection resistor (~1k) if you want to connect it to a socket. Otherwise the PIC can be destroyed. Best wishes Dieter Doepfer
2008-12-18 by Guy Drieghe D.
Hi folks, Amazing what one can learn about sine waves after a month of being off- line... ;-) Not sure if this is the right place to ask, but I recently re-acquired my old hi-end modular DIY synth, and want to try to either resurrect it, or sample it for valuable spare parts. The thing got a lot of CEM chips in it, and I was wondering if there's a quick way to check if these are still okay (out of their sockets -- the PSU has been blown). I could save some serious bucks with a-111's when the CEM 3340's would still be working... To clarify: I'm still on "idiot level" in regards to electronics DIY, but have some basic measuring equipment (DMM) available. Thanks ! _guy
> Hi folks, > > Amazing what one can learn about sine waves after a month of being off- > line... ;-) > > Not sure if this is the right place to ask, but I recently re-acquired > my old hi-end modular DIY synth, and want to try to either resurrect > it, or sample it for valuable spare parts. The thing got a lot of CEM > chips in it, and I was wondering if there's a quick way to check if > these are still okay (out of their sockets -- the PSU has been blown). > I could save some serious bucks with a-111's when the CEM 3340's would > still be working... > > To clarify: I'm still on "idiot level" in regards to electronics DIY, > but have some basic measuring equipment (DMM) available. > > > Thanks ! > > _guy The easiest way is to order an A-111-1 without CEM3340 and try which of the CEM3340 are working. I'm confident that at least one will be working. Of course you could built a circuit to test the CEM3340 but that's about 80% of the A-111-1 circuitry. Best wishes Dieter Doepfer
Thanks, Dieter ! If only to prove my point that I'm an idiot... I have several A-111's [with decent sines!], and of course it never occurred to me to use them as a perfectly valid and simple 3340 testbed. Doh ! cheers, _guy (back in kindergarten now)
> > Hi folks, > > > > Amazing what one can learn about sine waves after a month of being > off- > > line... ;-) > > > > Not sure if this is the right place to ask, but I recently re- > acquired > > my old hi-end modular DIY synth, and want to try to either resurrect > > it, or sample it for valuable spare parts. The thing got a lot of > CEM > > chips in it, and I was wondering if there's a quick way to check if > > these are still okay (out of their sockets -- the PSU has been > blown). > > I could save some serious bucks with a-111's when the CEM 3340's > would > > still be working... > > > > To clarify: I'm still on "idiot level" in regards to electronics > DIY, > > but have some basic measuring equipment (DMM) available. > > > > > > Thanks ! > > > > _guy > > The easiest way is to order an A-111-1 without CEM3340 and try which > of the > CEM3340 are working. I'm confident that at least one will be > working. Of > course you could built a circuit to test the CEM3340 but that's > about 80% of > the A-111-1 circuitry. > > Best wishes > Dieter Doepfer
2008-12-18 by Doug
Hi Dieter, yay! Thanks, Doug --- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote: > > > Hi folks using the A-152 with a cv input immediately gives rise to the > > need for a trigger on address selection. I'm thinking a socket for > > this could fit at the bottom of the dig outs section. Has anyone done > > this? > > > > Another thought is a difference or differentiator module that could > > generate triggers on discontinuities. Something like this could be > > built from an analog shift register and a comparator, I suppose! > > > > Thanks, > > Doug > > Not necessary :-) > > Module A-152 has a non-published feature (valid for all A-152 manufactured > later than October 2004): RC4 of the PIC16F676 outputs a short 5V trigger > signal whenever the address changes. RC4 is pin 6 of the PIC16F676 and is > also available on pin 2 of the expansion connector JP6 (next to the bus > connector on the A-152 main board / board A). Attention: the signal is not > buffered/protected. You should at least add a protection resistor (~1k) if > you want to connect it to a socket. Otherwise the PIC can be destroyed.
> > Best wishes > Dieter Doepfer >
