Bus Board connection!
2008-12-17 by gabu_004
Hello Group! Anyone would have a suggestion on how I could expand a Doepfer bus board? By that I mean add up more connections (as in I'm using many small modules but miss space to connect them)... and no worries, the power consumption doesn't bust the case,s limit! thanks y'all g.
2008-12-17 by Daniel Ornelas
Plan B Model 1 would be a nice fit: http://www.ear-group.net/model_1.html On Tue, Dec 16, 2008 at 7:04 PM, gabu_004 <gabu_004@yahoo.com> wrote: > Hello Group! > > Anyone would have a suggestion on how I could expand a Doepfer bus board? > By that I mean add up more connections (as in I'm using many small modules > but miss space > to connect them)... and no worries, the power consumption doesn't bust the > case,s limit! > > thanks y'all > > g. > > > ------------------------------------ > > Yahoo! Groups Links > > > > [Non-text portions of this message have been removed]
2008-12-17 by James Husted
You could add connectors to one end of the ribbon cables and plug them into two adjacent modules or more. The ribbon connectors will get shorter of course but you can at least double the count without much trouble. -James > > > On Tue, Dec 16, 2008 at 7:04 PM, gabu_004 <gabu_004@yahoo.com> wrote: > > > Hello Group! > > > > Anyone would have a suggestion on how I could expand a Doepfer bus > board? > > By that I mean add up more connections (as in I'm using many small > modules > > but miss space > > to connect them)... and no worries, the power consumption doesn't > bust the > > case,s limit! > > > > thanks y'all > > > > g. > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed]
2008-12-17 by Laurie Biddulph
Just fit another board in the rack. Just make sure you get its power from the same point the existing board gets it's power (i.e. don't daisy-chain the boards). You may have to make some adjustment to the connections to do that. Best Regards (Mr) Laurie Biddulph Phone: +61 (0)2 4340 0938 Mobile: 0400 257 645 Elby Designs ABN: 70 022 727 605 http://www.elby-designs.com This e-mail and any files transmitted with it are confidential and intended for the addressee only. If you are not the addressee you may not copy, forward, disclose or otherwise use it, or any part of it, in any form whatsoever. If you have received this e-mail in error please notify the sender and ensure that all copies of this e-mail and any files transmitted with it are deleted. Any views or opinions represented in this e-mail are solely those of the author and do not necessarily represent those of Elby Designs. Although this e-mail and its attachments have been scanned for the presence of computer viruses, Elby Designs will not be liable for any losses as a result of any viruses being passed on. Please consider the environment before printing this email ----- Original Message -----
From: "gabu_004" <gabu_004@yahoo.com> To: <Doepfer_a100@yahoogroups.com> Sent: Wednesday, December 17, 2008 2:04 PM Subject: [Doepfer_a100] Bus Board connection! > Hello Group! > > Anyone would have a suggestion on how I could expand a Doepfer bus board? > By that I mean add up more connections (as in I'm using many small modules > but miss space > to connect them)... and no worries, the power consumption doesn't bust the > case,s limit! > > thanks y'all > > g. > > > ------------------------------------ > > Yahoo! Groups Links > > > >
2008-12-17 by yahoo@doepfer.de
> Hello Group! > > Anyone would have a suggestion on how I could expand a Doepfer bus board? > By that I mean add up more connections (as in I'm using many > small modules but miss space > to connect them)... and no worries, the power consumption doesn't > bust the case,s limit! > > thanks y'all > > g. The most economic solution is to make special Y-type bus cables with double length. I.e. a 40 cm longe ribbon cable with one 16 pin female header in the center of the cable (this is connected to the bus board) and one 10 pin or 16 pin female header on each end. Another solution is the usage of a special daisy-chain ribbon cable with one 16 pin female header on one end (connected to the bus board) and for example four 10 pin or 16 pin female headers with the required distances between the connectors. These are connected to the modules and daisy-chained from one module to the next one. But this type of multiple ribbon cable connection is recommend only for control modules but not for audio processing modules or VCOs. Best wishes Dieter Doepfer
2008-12-18 by gabu_004
Thanks allll!!! I should be able to make out something with those suggestions :D cheerzzzz g. --- In Doepfer_a100@yahoogroups.com, "Laurie Biddulph" <elby_designs@...> wrote:
> > Just fit another board in the rack. Just make sure you get its power from > the same point the existing board gets it's power (i.e. don't daisy-chain > the boards). You may have to make some adjustment to the connections to do > that. > > > Best Regards > > (Mr) Laurie Biddulph > Phone: +61 (0)2 4340 0938 > Mobile: 0400 257 645 > > Elby Designs > ABN: 70 022 727 605 > http://www.elby-designs.com > > This e-mail and any files transmitted with it are confidential and intended > for the addressee only. > If you are not the addressee you may not copy, forward, disclose or > otherwise use it, or any part of it, in any form whatsoever. If you have > received this e-mail in error please notify the sender and ensure that all > copies of this e-mail and any files transmitted with it are deleted. > Any views or opinions represented in this e-mail are solely those of the > author and do not necessarily represent those of Elby Designs. > Although this e-mail and its attachments have been scanned for the presence > of computer viruses, Elby Designs will not be liable for any losses as a > result of any viruses being passed on. > > Please consider the environment before printing this email > > ----- Original Message ----- > From: "gabu_004" <gabu_004@...> > To: <Doepfer_a100@yahoogroups.com> > Sent: Wednesday, December 17, 2008 2:04 PM > Subject: [Doepfer_a100] Bus Board connection! > > > > Hello Group! > > > > Anyone would have a suggestion on how I could expand a Doepfer bus board? > > By that I mean add up more connections (as in I'm using many small modules > > but miss space > > to connect them)... and no worries, the power consumption doesn't bust the > > case,s limit! > > > > thanks y'all > > > > g. > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > > >
2008-12-18 by Laurie Biddulph
Hi, Another option is hat I am shortly to release a 4-way busboard with power delay circuitry based on the Ken Stones CGS63. The power on circuitry provides a delayed-on for the 4 IDC power sockets and helps reduce switch-on loading on he power supply as well as ensure a cleaner start-up power rail for the attached modules. The delay circuitry can, of course, be left off providing a small 4-port bus board Best Regards (Mr) Laurie Biddulph Phone: +61 (0)2 4340 0938 Mobile: 0400 257 645 Elby Designs ABN: 70 022 727 605 http://www.elby-designs.com This e-mail and any files transmitted with it are confidential and intended for the addressee only. If you are not the addressee you may not copy, forward, disclose or otherwise use it, or any part of it, in any form whatsoever. If you have received this e-mail in error please notify the sender and ensure that all copies of this e-mail and any files transmitted with it are deleted. Any views or opinions represented in this e-mail are solely those of the author and do not necessarily represent those of Elby Designs. Although this e-mail and its attachments have been scanned for the presence of computer viruses, Elby Designs will not be liable for any losses as a result of any viruses being passed on. Please consider the environment before printing this email ----- Original Message -----
From: "gabu_004" <gabu_004@yahoo.com> To: <Doepfer_a100@yahoogroups.com> Sent: Friday, December 19, 2008 4:34 AM Subject: [Doepfer_a100] Re: Bus Board connection! > Thanks allll!!! > > I should be able to make out something with those suggestions :D > > cheerzzzz > > g. > > > --- In Doepfer_a100@yahoogroups.com, "Laurie Biddulph" <elby_designs@...> > wrote: >> >> Just fit another board in the rack. Just make sure you get its power from >> the same point the existing board gets it's power (i.e. don't daisy-chain >> the boards). You may have to make some adjustment to the connections to >> do >> that. >> >> >> Best Regards >> >> (Mr) Laurie Biddulph >> Phone: +61 (0)2 4340 0938 >> Mobile: 0400 257 645 >> >> Elby Designs >> ABN: 70 022 727 605 >> http://www.elby-designs.com >> >> This e-mail and any files transmitted with it are confidential and >> intended >> for the addressee only. >> If you are not the addressee you may not copy, forward, disclose or >> otherwise use it, or any part of it, in any form whatsoever. If you have >> received this e-mail in error please notify the sender and ensure that >> all >> copies of this e-mail and any files transmitted with it are deleted. >> Any views or opinions represented in this e-mail are solely those of the >> author and do not necessarily represent those of Elby Designs. >> Although this e-mail and its attachments have been scanned for the >> presence >> of computer viruses, Elby Designs will not be liable for any losses as a >> result of any viruses being passed on. >> >> Please consider the environment before printing this email >> >> ----- Original Message ----- >> From: "gabu_004" <gabu_004@...> >> To: <Doepfer_a100@yahoogroups.com> >> Sent: Wednesday, December 17, 2008 2:04 PM >> Subject: [Doepfer_a100] Bus Board connection! >> >> >> > Hello Group! >> > >> > Anyone would have a suggestion on how I could expand a Doepfer bus >> > board? >> > By that I mean add up more connections (as in I'm using many small >> > modules >> > but miss space >> > to connect them)... and no worries, the power consumption doesn't bust >> > the >> > case,s limit! >> > >> > thanks y'all >> > >> > g. >> > >> > >> > ------------------------------------ >> > >> > Yahoo! Groups Links >> > >> > >> > >> > >> > > > > > ------------------------------------ > > Yahoo! Groups Links > > > >
