A-117 jack trouble
2009-01-06 by Tommy DOG
Somehow the external control jack has become bent and it is difficult to make connection. I have tried to correct the problem using jewelers tools but I simply cannot get the two parts to be right. Is there a easy way to repair the jack?
2009-01-07 by Tommy DOG
I hate to interrupt all this imitating Buchla with a Doepfer question. I need to replace a jack socket and I need either a manufacturer source or something that would put me in the right direction. I looked on the Doepfer site but didn't find it. Thanks. TD --- In Doepfer_a100@yahoogroups.com, "Tommy DOG" <mrsvomit@...> wrote:
> > Somehow the external control jack has become bent and it is difficult > to make connection. > > I have tried to correct the problem using jewelers tools but I simply > cannot get the two parts to be right. > > Is there a easy way to repair the jack? >
2009-01-07 by Tony Rolando
Part number: CL1384 In the UK: http://www.rapidonline.com/Cables-Connectors/Connectors-Audio-Video/Jack/3.5mm-Mono-PCB-jack-socket/63491/kw/cliff In the USA: http://www.cliffusa.com/content.asp?PID=7&Page=2 You might also read this: http://www.doepfer.de/faq/a100_faq.htm#contact%20problems Tommy DOG wrote:
> > I hate to interrupt all this imitating Buchla with a Doepfer question. > > I need to replace a jack socket and I need either a manufacturer > source or something that would put me in the right direction. > > I looked on the Doepfer site but didn't find it. > > Thanks. > TD > > --- In Doepfer_a100@yahoogroups.com > <mailto:Doepfer_a100%40yahoogroups.com>, "Tommy DOG" <mrsvomit@...> wrote: > > > > Somehow the external control jack has become bent and it is difficult > > to make connection. > > > > I have tried to correct the problem using jewelers tools but I simply > > cannot get the two parts to be right. > > > > Is there a easy way to repair the jack? > > > >
2009-01-07 by yahoo@doepfer.de
> Part number: CL1384 > > In the UK: > > http://www.rapidonline.com/Cables-Connectors/Connectors-Audio-Vide > o/Jack/3.5mm-Mono-PCB-jack-socket/63491/kw/cliff > > In the USA: > > http://www.cliffusa.com/content.asp?PID=7&Page=2 We don't use the CL1384 but the CL13841. There are some mechanical differences (slightly other dimensions) and the CL13841 has so-called "curly" contacts for a better contact. As far as I remember the CL1384 is the old version of the socket. We do not use it since many years because of the contact problems. Best wishes Dieter Doepfer
> I hate to interrupt all this imitating Buchla with a Doepfer question. > > I need to replace a jack socket and I need either a manufacturer > source or something that would put me in the right direction. > > I looked on the Doepfer site but didn't find it. > > Thanks. > TD It is available as spare part from the Doepfer representative in your country. You find it also in our price list in the spare parts section. It's manufactured by Cliff/UK. The order no. is CL13841 Best wishes Dieter Doepfer
Thanks Dieter. I have yet to locate any in small quantities for sale in the US. I wonder whether one can make a temporary substitute with a standard jack socket or does one need all 4 contacts. TD --- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote: > > > Part number: CL1384 > > > > In the UK: > > > > http://www.rapidonline.com/Cables-Connectors/Connectors-Audio-Vide > > o/Jack/3.5mm-Mono-PCB-jack-socket/63491/kw/cliff > > > > In the USA: > > > > http://www.cliffusa.com/content.asp?PID=7&Page=2 > > We don't use the CL1384 but the CL13841. There are some mechanical > differences (slightly other dimensions) and the CL13841 has so-called > "curly" contacts for a better contact. As far as I remember the CL1384 is > the old version of the socket. We do not use it since many years because of
> the contact problems. > > Best wishes > Dieter Doepfer >
2009-01-08 by waynerdlance
you can order straight from cliff. there number is 1 (785) 862-2543. order the ones dieter said with the curly contacts. they are $.85 each for a quantity of 25 or more so less quantity might be a little more. ask for mike he is in sales. Lance --- In Doepfer_a100@yahoogroups.com, "Tommy DOG" <mrsvomit@...> wrote:
> > Thanks Dieter. > > I have yet to locate any in small quantities for sale in the US. > > I wonder whether one can make a temporary substitute with a standard > jack socket or does one need all 4 contacts. > > TD > > --- In Doepfer_a100@yahoogroups.com, <yahoo@> wrote: > > > > > Part number: CL1384 > > > > > > In the UK: > > > > > > http://www.rapidonline.com/Cables-Connectors/Connectors-Audio-Vide > > > o/Jack/3.5mm-Mono-PCB-jack-socket/63491/kw/cliff > > > > > > In the USA: > > > > > > http://www.cliffusa.com/content.asp?PID=7&Page=2 > > > > We don't use the CL1384 but the CL13841. There are some mechanical > > differences (slightly other dimensions) and the CL13841 has so-called > > "curly" contacts for a better contact. As far as I remember the > CL1384 is > > the old version of the socket. We do not use it since many years > because of > > the contact problems. > > > > Best wishes > > Dieter Doepfer > > >
2009-01-08 by yahoo@doepfer.de
> Thanks Dieter. > > I have yet to locate any in small quantities for sale in the US. > > I wonder whether one can make a temporary substitute with a standard > jack socket or does one need all 4 contacts. > > TD That depends upon the module and the in/output in question. In ~90% of all cases only two terminals are actually used (GND and tip). But if the socket has a switching contact the terminal of the switched tip has to be wired too. Best wishes Dieter Doepfer
2009-01-08 by Tommy DOG
This is the socket for the external control input. It is probably a switching connector. TD --- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote: > > > Thanks Dieter. > > > > I have yet to locate any in small quantities for sale in the US. > > > > I wonder whether one can make a temporary substitute with a standard > > jack socket or does one need all 4 contacts. > > > > TD > > That depends upon the module and the in/output in question. In ~90% of all > cases only two terminals are actually used (GND and tip). But if the socket
> has a switching contact the terminal of the switched tip has to be wired > too. > > Best wishes > Dieter Doepfer >
> This is the socket for the external control input. > It is probably a switching connector. > > TD Right! Best wishes Dieter Doepfer
Thanks Lance. Done & done. --- In Doepfer_a100@yahoogroups.com, "waynerdlance" <lance.iden@...> wrote: > > > you can order straight from cliff. there number is 1 (785) 862-2543. order the ones dieter > said with the curly contacts. they are $.85 each for a quantity of 25 or more so less > quantity might be a little more. ask for mike he is in sales. > > Lance > > > --- In Doepfer_a100@yahoogroups.com, "Tommy DOG" <mrsvomit@> wrote: > > > > Thanks Dieter. > > > > I have yet to locate any in small quantities for sale in the US. > > > > I wonder whether one can make a temporary substitute with a standard > > jack socket or does one need all 4 contacts. > > > > TD > > > > --- In Doepfer_a100@yahoogroups.com, <yahoo@> wrote: > > > > > > > Part number: CL1384 > > > > > > > > In the UK: > > > > > > > > http://www.rapidonline.com/Cables-Connectors/Connectors-Audio-Vide > > > > o/Jack/3.5mm-Mono-PCB-jack-socket/63491/kw/cliff > > > > > > > > In the USA: > > > > > > > > http://www.cliffusa.com/content.asp?PID=7&Page=2 > > > > > > We don't use the CL1384 but the CL13841. There are some mechanical > > > differences (slightly other dimensions) and the CL13841 has so-called
> > > "curly" contacts for a better contact. As far as I remember the > > CL1384 is > > > the old version of the socket. We do not use it since many years > > because of > > > the contact problems. > > > > > > Best wishes > > > Dieter Doepfer > > > > > >
