Doepfer
question about the A-138c
2009-01-08 by mirror_saw7778
if one of the pots is at 12 o'clock - is the signal at zero / silent /
muted?
I am not sure if the module just adds gain or if it starts by
attenuating, then adding gain.
Hope that made sense.
Re: [Doepfer_a100] question about the A-138c
2009-01-08 by achtung_999
For what I understood & measured with a volt meter:
At zero it is muted/silent.Fully clockwise it is just passing through the
signal.
Fully anti-clockwise it is passing through the signal inverted.
Anything in between is attenuation.
Extra feature: if nothing is patched in to channel 1 it serves as an offset
generator. (Adding/subtracting accordingly to which way you turned its pot)
My 138c manages to add 5.8 volt and subtract 6.9 volt.
 Hope that helps.
Ernst
> muted?
