Doepfer
Re: Processing Rack Suggestions
2009-01-11 by zaum
> "but that
> said you can get a much cleaner BBD sound in other units"
> what other manufacturers would you suggest?
Not cheap or Eurorack but the Moogerfooger gives you an easy to use
BBD sound with CV on the main and relative high fidelity in a longer
delay range. The RS-120 Module previously talked about has a short
delay range that lies entirely below the Moogerfooger.
I have a Blacet Time Machine (Frac format), it has some clean up
circuitry for the BBD (not bypassable). It has bipolar feedback and
lets you run the chip in more extreme ranges - like the Doepfer and
unlike the Moogerfooger. It falls inbetween in terms of fidelity, the
Moogerfooger sounds substantially cleaner.
While not a module and not VC controllable at all, the BBD based
Behringer Vintage delay pedal with  300ms of delay. Costs under US
$30. I keep thinking maybe one might be able to attach a vactrol
controller to the pots. There is no onboard LFO.
Cwejman announced a quad line delay. Don't know if it will be analog.
The individual CV and outs seem like a good choice for putting
together ensemble effect
Oh and by the way, the ASystems RS-310 Reverb/Chorus uses a
multitapped chip as does the A-188-2. It's a substantially cleaned up
sound in comparison but gives you no real indepth control. Just a VC
rate and wet/dry mix, feedback is manual and output is just mono.
nick kent
2009-01-12 by Ken
Thanks for all the replies.
I guess I figured the RS-120 would be more about fidelity and the A-
188 would be more about experimentation. I guess it's horses for
courses. I'll probably end up going for a A-188.
Does anybody have experience with the the A-188-2. Would I be as well
to get that rather than an A-188-1 with a set number of stages.
Also does anybody have any suggestion for a good VCA. The A-131 VCA is
good but can be a little noisy.
thanks
Ken
--- In Doepfer_a100@yahoogroups.com, zaum <zaum@...> wrote:
> > "but that
analog.
up
> nick kent
Re: [Doepfer_a100] Re: Processing Rack Suggestions
2009-01-12 by Sean Williams
Ken
I have a few of the old CEM A-131 modules and a couple of Analogue
Systems RS-180. I felt that the A-131 was a bit weak in comparison,
and would use the RS-180 as a preference - I'm not going to try and
describe the sound difference too much, suffice to say that the
RS-180 seems louder and cleaner, so much so that you can back off the
CV-in without feeling like you're compromised by the noise floor.
Having Log and Lin on one module is a really useful feature too.
Haven't tried the newer A-131 or the A-132-3 which gets praised quite
a bit, but I still get some good use out of the old A-132.
sean
>thanks
>Ken
>--- In
><mailto:Doepfer_a100%40yahoogroups.com>Doepfer_a100@yahoogroups.com,
>>  > "but that
>the
>analog.
>up
>>  nick kent
2009-01-13 by nicholas_kent
Now you just have to pick how many stages you want (unless you want to
swap chips from time to time). The RS-120 is only available with
moderate short delays for better or worse. Depending on the chip with
Doepfer you can have delays more usable for one purpose and less for
another. I actually wouldn't mind a really short A-188-1 since I have
the 4096 one.
It's not a replacement. To me it's another concept's implementation.
This time you can access the individual taps of a multitapped delay
chip, something quite uncommon if not unique in a comerical product.
The RS-310 is sort of Analogue System's earlier take, no deep access
at all beyond CV delay time, no stereo but substantially cleaner
sound. The A-188-2 is really interesting but it's even noisier and
harder to tame the artifacts on than the A-188-1
What kind of noise? Just a high noise floor or something else like
signal leakage, hum? Maybe you've already examined it closely but it's
worth checking your gain and signal structure in general. It could be
you are offsetting it with the gain knob and don't realize it, or
maybe you have a low signal somewhere that shouldn't be so low. I've
really never encountered audible noise out of the VCA that I wasn't
expecting. On the other hand sometimes VCAs seem simpler than they are
to patch in. I know I've gotten results I didn't expect because of
knob offsets didn't notice. There all those old stories about the
broken Arp synth that was really the VCA offset slider confusing someone.
I would guess the cwejman is higher spec, though I only have the VM-1
where the VCA isn't isolated. The ASystems VCA is nice that it has
both linear and "log" inputs though ergonomically it has an offset
knob where you think the non-existent output level knob should be
which threw me a few times.
nick
