Doepfer
Identifying the (possibly) dodgy IEC power connectors
2009-02-03 by Tim Stinchcombe
Hi list,
After all this talk of which power inlet is good/bad etc., I decided to
take a few snaps of the one in the second-hand case I had to replace,
and made a page for it at my website:
http://www.timstinchcombe.co.uk/synth/iec_mod/iec.html
Also there is the part no. of a suggested replacement, which might be
of some use (or at least save someone else spending hours and hours
looking for a replacement which is _just_ the right size). If there is
anything glaringly wrong there, I'd appreciate being informed!
Tim
Re: [Doepfer_a100] Identifying the (possibly) dodgy IEC power connectors
2009-02-03 by Sean Williams
... and here's what one of mine looked like after the event:
http://monosynthorchestra.com/images/doepfer_meltdown.jpg
I'd be surprised if there were many left now that haven't failed, but
if it happens to you, an even cheaper way around it is to crack the
metal can, cut/lever away the plastic/goo and remains of the filter,
until all that's left are the metal connectors, then simply resolder
the mains wires to these terminals. This means no expense, no
sourcing of parts, and no more than 2 hours work.
sean
>Hi list,
><http://www.timstinchcombe.co.uk/synth/iec_mod/iec.html>http://www.timstinchcombe.co.uk/synth/iec_mod/iec.html
>Thanks,
>Tim
2009-02-03 by Julian
>>...crack the metal can, cut/lever away the plastic/goo and remains of the filter, until all that's left are the metal connectors,
>>then simply resolder the mains wires to these terminals.
Id just like to add weight to Sean's comments, as thats how ive fixed a couple of old G6s.
It was some time ago, and i cant remember the exact details, but i remember it being messy rather than that intellectually
difficult.
As the time, i think i sourced the originals, but i wasnt keen on paying the (now) extended price for them!
2009-02-03 by James Husted
Tim -
You could always use the left over switch as a Ground Lift switch.
Might as well put it to use.
-James
On Feb 3, 2009, at 5:46 AM, Tim Stinchcombe wrote:
> Hi list,
> to
> Thanks,
> Tim
AW: [Doepfer_a100] Identifying the (possibly) dodgy IEC power connectors
2009-02-04 by yahoo@doepfer.de
> -James
Please don't do that! Due to electrical safety reasons this is not allowed
because the housing is no longer earthed in this case ! If one of the mains
leading cables becomes loose and touches the case there is serious danger to
life. This is why the case has to be always to be connected to earth. I know
that this a popular procedure but I'd strictly disadvise.
Best wishes
Dieter Doepfer
> Hi list,
> Thanks,
> Tim
Excellent work. Thank you very much for your assistance.
Dieter Doepfer
