Doepfer
Peter Grenader's beasty
2002-07-02 by ethanzer0
Hi Ho,
Is there a site that documents this
modular?  I am curious about the
modules and the construction of the
cabinet.
Ethan
Re: Peter Grenader's beasty
--- In Doepfer_a100@y..., "ethanzer0" <ethanzer0@y...> wrote:
> Hi Ho,
> cabinet.
> Thanks,
> Ethan
Never mind, I found the link. :)
Thanks,  Ethan.
2002-07-02 by petergrenader
> cabinet.
Yes...go here:
http://www.allegrobikes.com/synth.html
the second section talks about a mp3 of a piece of music I've
just completed called Electrolux.  The soundfile will not be
loaded for about 3 hours.  It's a big one (9 megs).
But you can see a blow by blow description of the machine
although at the time, I did not yet have my Doepfer Frequency
shifter or pulse divider or the Analogue Systems' mixer, so there
are some differences from what's shown in the picture.  I have
removed my Analogue Solutions Unity gain mixer and the two
mults (those three are going to be installed on the strip on top)
and I have put the A-192 into it's own little chassis because it's
not going to get the use as it once was and I figure I can pull it
out when needed.
The chassic was home built.  Obviously, I modeled it after the
Buchla 200.  I did this because I always liked the ergonomics
that afforded me - everything is within reach.  It's made of 3/4
inch MDF.  I made a scaledrawing in Illustrator and had a scale
printout of the side panels made which I used as a cutting
template. I had the finished box painted by a local midi rack
manufacturer.
The modules themselves are screwed into four 16 gage sheet
metal boxes which are in turn bolted to the inside of the cabinet.
I used 16 gage because i needed enough meat for the threads
to bite.  I used sheet metal over alloy because I had a connection
to get them free.  The upside, it's so freaking heavy I should
never have to worry about theft!  The downside:  it's FREAKING
HEAVY.  Easily 75 pounds or something like that.  Next time, I
think I'll make the expense to have alloy boxes made, although
that is expensive, about $500.  Being able to get them free in
sheet metal was too much of a temptation for me.
Out of view, behind the modlues there is a space for the three
power supplies (two Doepfer's and one Lambda +/-15 for the
Blacet stuff).  Yes, there are ten Blacet moldues in there which I
made custom photo sensitive alluminum faceplates for!
All of the modules onthe top row (from right of the second Blacet
Processor are all home built and designed:  2 channel voltage
processor, AND/NAND gate, a positive biased voltage inverter,
noise source, Moog Lowpass filter/envelope follower clone, a
programmable pulse generator with LFO and the 8x2
sequencer.
The future expansion panel (blank one next to the MAQ 16/3) is
probably going to have a touch plate trigger source I'm working
on, a flanger and the MIDI to CV output jacks.
hope this helps.
P
> Hi Ho,
> cabinet.
> Thanks,
> Ethan
> > cabinet.
> Yes...go here:
> hope this helps.
> P
It is very impressive to say the least!
I aspire to something similar in the
near future.  I have some Doepfer modules
now and am considering some DIY and some
others.  I am curious why you did not opt
for bannana jacks on the DIY and custom
Blacet stuff as I am considering retro-
fitting my A100 stuff with bannana jacks.
BTW, wasn't there someone in this group
who already did that?
Thanks again!
Ethan
Having been a Buchlidian and a past Serge owner, I would have much
preferred bananas, but...it seemed like too much of an undertaking so
I left it as is.
thanks for the kind words though.  I believe Kris Rhen is the person
who banana-ized his A100.  Kris?  Yes?
-Peter
> > > cabinet.
> > Yes...go here:
> > hope this helps.
> > P
> Thanks again!
> E
2002-07-02 by cuari7
> -Peter
No, dude! It was me! In fact I still have the same DID (Doepfer In
Drag), but have since changed the knobs, removed the keyboard and
added more Doeph modules (joystick, mixer, resonator, vca, pedal
interface, VC switch, volt. inverter).
Check it out at www.stucki.com/krhen/downloads/jdiaz
Kris Rhen is the nice guy who is hosting my pics on his site.
cuari (pronounced qwattee', with accent at the end. Rhymes with Marie)
> > > > cabinet.
> > > Yes...go here:
> > > hope this helps.
> > > P
> > Thanks again!
> > E
Wow!
Ok, I thought Kris had something to do with it.  Lemme ask
you...was it worth the work or was it scary as sheet?
What I am worried about is loosing PCB pads from overheating
during de-soldering.  Was that horrible?
Trust me, I would LOVE to have bananas, even though Pomonas
are so damned expensive.
-Peter
> > -Peter
In
keyboard and
pedal
with Marie)
> > > > > cabinet.
> > > > Yes...go here:
> > > > hope this helps.
> > > > P
> > > Thanks again!
> > > E
2002-07-03 by ethanzer0
Thats what I was looking for!
Can you tell us a little about
the project?  What kind of
jack did you get i.e. insulated,
etc? and which brand? How did
you connect + and - to the
doepfer PCB, etc...
Thanks again,
Ethan
