Doepfer
Re: [Doepfer_a100] diy DIN-Sync to analogue clock converter
2009-02-26 by Florian Anwander
This is an answer to a private mail, I received from Coy via Yahoo, but
the give reply adress did fail. Because the request it might be of
public interest I send my answer to Coy the list.
Hi Coy
> Does this circuit just divide the 16th note clock? Can it perform a
> mulitplication such as 32nd or 64ths?
It does divide just to 16th, but 32nd (or 24th triplets) would be
possible without a problem. I could modify the pcb to this.
64th's aren't possible with DIN-sync. At least not in a straight way,
because DIN-sync provides 96th and dividing by one and a half is not
really easy (requires a PLL).
Florian
Re: diy DIN-Sync to analogue clock converter
2009-02-26 by Carlos
would your adaptor circuit work the other way around (regular clock to
dyn sync) or just one way?
C.
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...>
but
> Hi Coy
a
way,
> Florian
Re: [Doepfer_a100] Re: diy DIN-Sync to analogue clock converter
2009-02-26 by Robbert Jan Rink
That would be something I'd be interested in. Syncing my 606 to lfo... Have
the A100 as master.
regards,
Robbert
> C.
> --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>,
> but
> > Hi Coy
> a
> way,
> > Florian
Hi Carlos
It is one way. Regular clock to DIN-sync requires some more advanced
processor based electronics. The sync-lock from innerclock Systems does
that: www.innerclocksystems.com
Florian
2009-02-27 by Carlos
Excellent exactly what I want but, BUT can't find it anywhere on
either AH or schneider's. any ideas?
carlos
wrote:
> Hi Carlos
clock to
does
> Florian
2009-02-27 by Florian Anwander
Hi Carlos
I think you can get them only at AH or Schneiders. At least, thats what
David from innerclock is writing on his website.
Florian
