Doepfer MTV16 and MIDI buffer?
2009-03-26 by ysinollaysi
From the Manual: "The Midi input of MTV16 is not suitable for large amounts of Midi data ... as the Midi in buffer is only 48 bytes." What does this mean in practise? I don't have a faintest idea how much 48 bytes is in this context. - Markus
2009-03-26 by yahoo@doepfer.de
> From the Manual: "The Midi input of MTV16 is not suitable for > large amounts of Midi data ... as the Midi in buffer is only 48 bytes." > > > What does this mean in practise? I don't have a faintest idea how > much 48 bytes is in this context. > > - Markus Please contact our programmer Christian Assall (software@doepfer.de). He can tell you what this actually means. Best wishes Dieter Doepfer
2009-03-26 by Florian Anwander
Hello > From the Manual: "The Midi input of MTV16 is not suitable for large > amounts of Midi data ... as the Midi in buffer is only 48 bytes." > What does this mean in practise? I don't have a faintest idea how > much 48 bytes is in this context. Unfortunately it is not really very meaningful. Basically a MIDI-Event (e.g. one controller change, one note) consists of three bytes. The three bytes tell you byte 1) "what kind of data": note, controller,pitchbend..., byte 2) "which channel and which data", e.g.: for a note channel+C5, for a controller channel+Volume, byte 3) "which value" e.g. for note velocity=96, for control volume=122 So you see, that the inputbuffer is able to contain the information for 16 controller values [*]. So if on your MIDI-cable there is not only the Controllerinfo for this MTV16, but also many other informations (e.g. Notes from your Sequencer), then the input buffer will have an overflow - data will be lost. So, if the MTV16 is controlled by a computer, it should be controlled via a dedicated MIDI-Port, which does not transfer anything else but the Controllers for the MTV16. Florian [*]If the sending device uses the so called active mode (which I won't explain for now), it may be up to 23 events. But still this is not very much.
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...> wrote: > > Hello > > > From the Manual: "The Midi input of MTV16 is not suitable for large > > amounts of Midi data ... as the Midi in buffer is only 48 bytes." > > What does this mean in practise? I don't have a faintest idea how > > much 48 bytes is in this context. > > Unfortunately it is not really very meaningful. > > Basically a MIDI-Event (e.g. one controller change, one note) consists > of three bytes. > The three bytes tell you > byte 1) "what kind of data": note, controller,pitchbend..., > byte 2) "which channel and which data", e.g.: for a note channel+C5, for > a controller channel+Volume, > byte 3) "which value" e.g. for note velocity=96, for control volume=122 > > > So you see, that the inputbuffer is able to contain the information for > 16 controller values [*]. So if on your MIDI-cable there is not only the > Controllerinfo for this MTV16, but also many other informations (e.g. > Notes from your Sequencer), then the input buffer will have an overflow > - data will be lost. > > So, if the MTV16 is controlled by a computer, it should be controlled > via a dedicated MIDI-Port, which does not transfer anything else but the > Controllers for the MTV16. > > > Florian > > > > [*]If the sending device uses the so called active mode (which I won't > explain for now), it may be up to 23 events. But still this is not very > much. > Thank you Florian for your informative answer! Based on this information I'd say that 48 bit is awfully low value. Although I'm sure it's (barely) enough for me because I was going to use it on a separate midi port anyway. Have to check out if it's possible in Renoise to filter out "basic" midi messages such as start/stop, bpm etc. just on one port. - Markus
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...> wrote: > > Hi Markus > > > Based on this information I'd say that 48 bit is awfully low value. > > Although I'm sure it's (barely) enough for me because I was going to use it on a separate midi port anyway. > The main question to Chris Assall will be, how quick the buffer content > is handled and then cleared. > > I don't think you will be able to cause an overflow, if the midi-port > contains only the noteinfos for the A-100, MIDI-Clock and the > Controllers for the MTV16. But other info should be avoided. > > Florian > That one midi port will be dedicated to MTV16 _only_. Another midi port will handle the notes, gates, bend etc. to MCV24. Third one will trigger modular drums and drummachines. And fourth one will control everything else (if any non-modular gadgets will be used). I'll just try to overload MTV16 before mailing Chris. Got it today and will "build" it on monday.
Hi Markus > Based on this information I'd say that 48 bit is awfully low value. > Although I'm sure it's (barely) enough for me because I was going to use it on a separate midi port anyway. The main question to Chris Assall will be, how quick the buffer content is handled and then cleared. I don't think you will be able to cause an overflow, if the midi-port contains only the noteinfos for the A-100, MIDI-Clock and the Controllers for the MTV16. But other info should be avoided. Florian
