Re: AW: [Doepfer_a100] comments on the mini-schaltwerk module?
2009-04-15 by Bakis Sirros
the two independent clock inputs for raos 1-4 and 5-8 is a great idea! btw, i would vote for the 16 buttons per each row version (128 buttons in total). i prefer it to the 16 assignable buttons for all 8 rows. but, anyway, both versions would be fine for me. Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Doepfer_a100] group owner www. parallel - worlds - music. com www. myspace. com/ parallelworldsmusic www. myspace. com/ interconnectedmusic www. myspace. com/ memorygeist www. DiN. org. uk www. musicamaximamagnetica. com www. shimarecords. co. uk www. rubberrecords. gr Athens - Greece --- On Wed, 4/15/09, yahoo@doepfer.de <yahoo@doepfer.de> wrote:
Subject: AW: [Doepfer_a100] comments on the mini-schaltwerk module?
Date: Wednesday, April 15, 2009, 11:26 AM
> -----Ursprüngliche Nachricht--- --
> Von: Doepfer_a100@ yahoogroups. com
> [mailto:Doepfer_a100@ yahoogroups. com]Im Auftrag von John V. Talbert
> Gesendet: Mittwoch, 15. April 2009 01:52
> An: Doepfer_a100@ yahoogroups. com
> Betreff: Re: [Doepfer_a100] comments on the mini-schaltwerk module?
> > maybe there is not any info int he doepfer site, but you can
> see it running in the musikmesse a100 video here:
> http://www.sonicsta te.com/news/ 2009/04/06/ messe09-doepfer- modular-
> synth-video- action/
> > that's why i am asking for comments from people who attended
> the musikmesse.
> Is it the module with the columns of moving red lights in the lower
> right hand corner or the rightmost case? If so, it looks great! And
> I've always wished for something like a mini-Schaltwerk and I'd buy
> one right now if it were available. Why has Dieter been so quiet
> about it? Or did I just miss the discussion?
> John
It's a very early prototype of the planned module named "honey I shrunk the
schaltwerk" ;-)
We finished the two prototypes at the weekend before the Musikmesse. As it
was not sure if we could make it there was no time for an announcement. And
the two prototypes have only very limited functions so far:
prototype 1: matrix of 8 rows with 8 buttons and LEDs each (the final
version will probably have 16 buttons and LEDs per row), 8 trigger outputs
(during the Musikmesse used to trigger MFB drum modules), clock and reset
input, no additional functions like different first/last step,
presets/memories and so on
pototype 2 (not complete): 8x8 LED matrix with only one set of 8 buttons,
the buttons have to be assigned to one row, the final version will have
probably 16x8 (or 32x8) LEDs with one set 16 (or 32) buttons. This would
allow a very compact 16x8 (or 32x8) step trigger sequencer with a small
required space.
I added a picture of the two versions to our website:
www.doepfer. de/A100_pictures /A100_Schaltwerk .jpg. On the right side you see
version 1, on the left side version two (so far only the LED matrix that
displays the same as the version 1 but rotated by 90 degrees). The single
button row for version 2 has not been finished in time. Only the LED matrix
unit was finished. We think also about other applications of the LED matrix
(e.g. 8-fold level meter, X/Y position display, miniature
oscilloscope/ correlation meter and some more).
Everything is in a very early prototype state and we are not sure if both
versions (separate button for each step or only one set of buttons) will be
manufactured. In any case it will be a simple trigger sequencer with reduced
functions compared to Schaltwerk (not the same huge functions as the
Schaltwerk). Probably two (normalled) clock inputs for the rows 1-4 and 5-8
will be available to allow different tempos for the rows 1-4/5-8 (e.g. by
means of a trigger divider or two totally independent clocks). And some
presets/memories will be available, but probably not the extended functions
of Schaltwerk.
Before we continue with this module a lot of other stuff has to be finished
(Dark Energy, A-111-5, DSP-Module A-187-1, Matrix Mixer A-138m, Dual
Attenuator A-183-1, Offset/Polarizer A-183-2, Amplifier A-183-3, polyphonic
Midi/CV interface A-190-3, modulation wheel module A-174-2, foot controller
module A-177-2, CV/Gate-to-Midi interface, and some more ...)
Best wishes
Dieter Doepfer
