Doepfer
Power Supply Hardware
2009-05-27 by Greg Cerveny
I recently picked up a second hand a100p6 that was packed by
sandwiching it between two single 12" x 24" sheets of bubble wrap.  As
you might guess, the unit got to me damaged in the post.
The standoff posts that attach the heatsink/powersupply/case on the
left/interior side seem to have snapped off.  Other than a blown fuse
I just replaced, this case/power appear to be functioning as they
should.  I was able to remove the power supply and with needle-nose
pliers, unscrew the broken ends.  I've attached a picture of the
broken pieces.  Does anyone know where I could get a pair of
replacement stand-offs?
I'm assuming a power supply is a pretty rugged piece of equipment and
that despite the snapping standoffs, should be fine to use.  Anyone
have any reason to believe that I should replace the power supply?
Re: [Doepfer_a100] Power Supply Hardware
2009-05-27 by Florian Anwander
Hello Greg
I suggest to ask hardware@doepfer.de
> Anyone have any reason to believe that I should
I don't think so. The only danger might be broken solder joints. So it
would be helpful to get a sharp(!) high resolution picture of the
soldering side of the powersupply.
Florian
