Re: [Doepfer_a100] Power Supply Hardware
2009-05-27 by Bakis Sirros
hello, attachments are not allowed in the posts of this group. please, if you want, post the photo in the photos section of the group. thanks, best regards, Bakis. Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Doepfer_a100] group owner www. parallel - worlds - music. com www. myspace. com/ parallelworldsmusic www. myspace. com/ interconnectedmusic www. myspace. com/ memorygeist www. DiN. org. uk www. musicamaximamagnetica. com www. shimarecords. co. uk www. rubberrecords. gr Athens - Greece --- On Wed, 5/27/09, Greg Cerveny <greg.cerveny@gmail.com> wrote:
Subject: [Doepfer_a100] Power Supply Hardware
To: "doepfer_a100" <Doepfer_a100@yahoogroups.com>
Date: Wednesday, May 27, 2009, 8:02 AM
I recently picked up a second hand a100p6 that was packed by
sandwiching it between two single 12" x 24" sheets of bubble wrap. As
you might guess, the unit got to me damaged in the post.
The standoff posts that attach the heatsink/powersuppl y/case on the
left/interior side seem to have snapped off. Other than a blown fuse
I just replaced, this case/power appear to be functioning as they
should. I was able to remove the power supply and with needle-nose
pliers, unscrew the broken ends. I've attached a picture of the
broken pieces. Does anyone know where I could get a pair of
replacement stand-offs?
I'm assuming a power supply is a pretty rugged piece of equipment and
that despite the snapping standoffs, should be fine to use. Anyone
have any reason to believe that I should replace the power supply?
