Doepfer
Ableton Live -> USB -> MAUSI -> A-100
2009-11-30 by andyrubio
I'm new to the group and new to midi. And new to Ableton Live.
I've got midi messages from Ableton Live to control the gate and CV1 output of my MAUSI device but can't work out how to get another control from Ableton to get to the CV2 output (in this case I want it to control the frequncy of a filter). I'm sure it's as easy as boiling an egg but I'd sure appreciate a nudge in the right direction.
Many thanks in advance,
Andy
Re: [Doepfer_a100] Ableton Live -> USB -> MAUSI -> A-100
2009-11-30 by Bakis Sirros
hello,
i am not familiar with the MAUSI, but i guess the cv2 output should receive midi cc's very easily. you just have to check the MAUSI manual to see how you define which midi cc the cv2 will receive.
after you define this assignment, you have to go to the midi clip in ableton and draw a curve for this midi cc...
then the cv2 should output voltages according to this midi cc.
thanks,
best regards,
Bakis.
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
--- On Mon, 11/30/09, andyrubio <andyrubio@yahoo.com> wrote:
Subject: [Doepfer_a100] Ableton Live -> USB -> MAUSI -> A-100
Date: Monday, November 30, 2009, 6:39 PM
Andy
Re: Ableton Live -> USB -> MAUSI -> A-100
Thanks Bakis, that's great. good to know it should be quite straightforward.
Now the problem is this, the mausi manual: http://www.doepfer.de/maus_m_e.htm It's not clear to me what the text under the heading of "CONFIG Menu 6 / assign cv2" actually means particular this sentence:
Just select CONFIG menu 6 and transmit the controller via MIDI to MAUSI.
How do I "select CONFIG menu 6"?
Andy
--- In Doepfer_a100@yahoogroups.com, Bakis Sirros <synth_freak_2000@...> wrote:
> hello,
> thanks,
> best regards,
> Bakis.
> www. DiN. org. uk
> Athens - Greece
> --- On Mon, 11/30/09, andyrubio <andyrubio@...> wrote:
> From: andyrubio <andyrubio@...>
> Â
>       Hi,
> Andy
Re: [Doepfer_a100] Re: Ableton Live -> USB -> MAUSI -> A-100
and here is where Dieter comes in...
Dieter?
www. DiN. org. uk
Athens - Greece
Subject: [Doepfer_a100] Re: Ableton Live -> USB -> MAUSI -> A-100
Date: Monday, November 30, 2009, 8:42 PM
Now the problem is this, the mausi manual: http://www.doepfer. de/maus_m_ e.htm It's not clear to me what the text under the heading of "CONFIG Menu 6 / assign cv2" actually means particular this sentence:
Andy
--- In Doepfer_a100@ yahoogroups. com, Bakis Sirros <synth_freak_ 2000@...> wrote:
> hello,
> thanks,
> best regards,
> Bakis.
> www. DiN. org. uk
> www. musicamaximamagneti ca. com
> Athens - Greece
> --- On Mon, 11/30/09, andyrubio <andyrubio@. ..> wrote:
> From: andyrubio <andyrubio@. ..>
> To: Doepfer_a100@ yahoogroups. com
> Â
>       Hi,
> Andy
2009-12-01 by andyrubio
This manual for the A190.1 MIDI - CV/Sync Interface looks like it might tell me what I need to know. As far as I can tell, this module is simply the MAUSI in a different package. The manual for the A-190 seems more readable than the MAUSI's manual. I'll try it out tomorrow evening.
http://www.doepfer.de/a100_man/A190_man.pdf
> Dieter?
> www. DiN. org. uk
> Athens - Greece
> Â
> Thanks,
> Andy
> --- In Doepfer_a100@ yahoogroups. com, Bakis Sirros <synth_freak_ 2000@> wrote:
> > hello,
> > thanks,
> > best regards,
> > Bakis.
> > www. DiN. org. uk
> > Athens - Greece
> > --- On Mon, 11/30/09, andyrubio <andyrubio@ ..> wrote:
> > From: andyrubio <andyrubio@ ..>
> >       Hi,
> > Andy
